Old November 12th, 2017, 11:05 AM   #1
ScottF
Help please no start VERY intermittent crank
OK, go out earlier to run some errands and try to start the Probe. Will not start. Battery is good, starter whirrs when doing screw driver trick, and occasionally( once) attempted to crank over. All accessories work, IE radio etc...Car was running just fine yesterday, fired right up. Car had a KLZE swap about 2 months ago, new clutch, remanned disty and remanned starter. I did have a similar thing happen, but it was a loose positive terminal which I fixed by replacing both terminals. This is stumping me as I drove it as recently as 10PM last night( Arby's run) and it started fine. To recap, it is getting spark, starter is good battery is good. I can rule out bad timing belt( brand new when ZE was installed) Car is not seized( took a long breaker bar and was able to turn it quite nicely.
ScottF is offline   Reply With Quote
Old November 12th, 2017, 11:13 AM   #2
Does it crank over without a screwdriver? I am assuming that you used a screw driver because it wasn't turning over on it's own. In this case -you have a starter circuit problem.
KLZE Porsche is online now   Reply With Quote
Old November 12th, 2017, 11:15 AM   #3
ScottF
It makes a whirring noise when doing the screwdriver. Like the gears are spinning but the plunger is not engaging the gears to the flywheel if that makes sense
Old November 12th, 2017, 11:59 AM   #4
Starter! No doubt! The only way it would not be the starter is if you have sheared off all the teeth on the spur gear.
Old November 12th, 2017, 12:18 PM   #5
ScottF
Interesting. It does not even make whirring when I turn the ignition. only when I use the screwdriver. What would account for it the one time actually cranking but not starting? It makes sense, but should I also look at the clutch safety switch?
Old November 12th, 2017, 12:29 PM   #6
The starter is a one input engage and spin. So if it is not engaging but spinning then the starter is bad.
Old November 12th, 2017, 02:09 PM   #7
Level 9
I was just kind of stumped not long ago when I got a new starter that was even bad right out of the box. I thought my motor was seized until I spun it. I now have my 3rd starter in the car now. Autozone I noticed changed the solenoid from their previous stock so looking like they were possibly problematic. At lease they were free replacements. +1 on the starter
Old November 12th, 2017, 03:48 PM   #8
ScottF
Interesting, I'm not sure how this applies to my situation, but I will keep on the lookout for anything different.
Old November 13th, 2017, 09:09 AM   #9
ScottF
UPDATE: Started right up today. Signs are pointing toward clutch safety switch being the culprit.
Old November 13th, 2017, 01:50 PM   #10
DatVash
I'm about to figure out how to bypass that safety. Each time I go to start my car I have to turn the key multiple times till it engages the starter. My 95 had it disabled in it with a push button start, so I know it can be done.
DatVash is offline   Reply With Quote
Old November 13th, 2017, 04:35 PM   #11
Level 9
Rereading though here when you turn your key and you hold the key turned if it clicks and doesn't spin continue to hold the key turned and let out the clutch and press it again. My 95 I have an issue as well I have to push the clutch a few times before the starter will engage.
So kind of sound rereading the post that essentially instead of turning the key back and forth your foot is turning the key back and forth if that makes any sense? Lol then yes I'm assuming both of our switches are having issues. I've been living with mine doing that for quite awhile now.
Completely bypassing that switch I would not recommend because if you ever accidentally start it in gear and something distracting is going on I would hate to see anybody's car jump into something or someone. Assuming these switches can't be much to replace. Just a little pain to get to..
Old November 16th, 2017, 10:51 AM   #12
DatVash
I'll test it out that way, in attempt to be sure that it is the safety switch. I'll have to see if it can be ordered too.
Old November 17th, 2017, 10:22 AM   #13
ScottF
Update 2: Went to drive it yesterday and today, both times would not start even after bypassing clutch switch. Though ALMOST started once today...This is getting frustrating as it will start occasionally but other times it's just dead. It is neither the battery nor starter itself. Like I have stated, engine not seized, starter good, battery good( tested at CCA for the brand and model) and when it DOES start it will do it just fine all day...When it does not start it will not start at all...Right now it's like a crap shoot
Old November 17th, 2017, 01:45 PM   #14
Level 9
Now when you say it won't start you mean you turn the key and then nothing happens at all? Or is there a click then nothing, or it's spinning and not engaging the flywheel? When you crank the car how many volts are you getting to the starter when the clutch is depressed and key turned to start position? If your getting 12v to the starter clutch in key to start the starter maybe on the fritz. All the connections nice and solid and grounds clean? No wires in the starting circuit getting that nice green corrosion going on that could be causing any possible issue?
My current problem personally is I can hold my key to start then it will click, release clutch press again click, and repeat until it decides it wants to work. Sometimes no problem sometimes it's a real pita!
Also are you still able to jump the solenoid to crank the car?
Old November 19th, 2017, 07:08 AM   #15
ScottF
I can hear the starter relay in the engine click, and when I turn the key nothing happens at all. When it does start, it starts right up on the first turn of the key. All connections do appear nice and solid and I did not see any green corrosion. I can jump the solenoid, but it just makes the whirring sound
Old November 19th, 2017, 11:02 AM   #16
Level 9
If you're jumping the solenoid and it's just spinning and not engaging the flywheel the starter is bad.
Old November 22nd, 2017, 09:41 AM   #17
ScottF
I was actually able get it to crank by jumping A to B yesterday with a screw driver, actually had it cranking for a good minute. Still will not turn over with the key however, I hear the relay click and nothing. I checked ignition switch connections for continuity and in all key positions there was no continuity so I assume that rules out the ignition switch.
Old November 22nd, 2017, 10:38 AM   #18
Level 9
Recheck neutral safety switch. There isn't too much involved in the starting circuit like klde Porsche stated above. If it's only spinning sometimes then question the solenoid, if it just clicks when the key is turned then you step on the clutch try to repeat stepping on the clutch to see if you can get it to engage.
Old December 1st, 2017, 12:42 PM   #19
ScottF
Talking
It was the clutch safety all along. Turns out the first time I tried jumping it, the wire I used I guess did not make contact with the female terminals inside the connector. Took forever to start, but the cranking and sputtering to life was music to my ears almost as sweet as Slayer and Metallica doing a duet...Finally it roared to life and I ran it a few minutes to blow some of the accumulated hydrocarbons out. Had to tape a note to the dash reminding me to not start the car in gear, but the point is, it's functional and since I know it works now, I am in no rush to fix the clutch switch
Old December 1st, 2017, 07:07 PM   #20
Level 9
Glad to hear you got it goin. My clutch switch had been messed up for awhile. Sometimes it starts first go, sometimes it's 1,2,3, or 20 times I have to push the clutch before it will decide it wants to let me start the damn thing lol. I haven't replaced it since I think I'm going to be looking for a different PGT in the spring to be the new project that has a better starting point than where mine currently sits at the moment.
What started crank/no start is now no crank/no start.. stencer 2nd Gen (93-97) V6 2.5L 19 February 11th, 2009 06:12 AM
Non intermittent to intermittent? z28forlife 2nd Gen (93-97) V6 2.5L 0 June 13th, 2008 09:15 PM
Very very very very insane motorcycles. Silver_Bullit Probe Lounge 4 December 5th, 2002 06:35 PM
crank crank crank thud crank crank iamdung 2nd Gen (93-97) V6 2.5L 29 May 1st, 2002 08:46 PM
