sweet, lets us know total cost for thep arts that fit playa, you ought to see if you can get a bulk discounti f this works and run a tranny rebuild BB!
The Ultimate Transmission Thread... Brainstorm Ideas Here!
BTW - we are gear limited not drag limited. According to GPS I got my 96 up to 143MPH ground speed before I ran out of gear....the car was still wanted to go though.
More about gearing.....I feel the stock gearing is nearly perfect....1st is low enough to provide plenty of umph off the line even with very sticky tires. 2nd is tall enough to use a hefty dose of nitrous in and really get the stretch its legs before making the two shorter shifts. For what its worth I found short shifting first and hitting nitrous early the best route to take. You really dont want to shorten 2nd gear because you will be traveling slow when you make your 2-3 shift and it will cost you more time. You see the faster you are going when you make a shift the less time you lose because you cover more ground.Last edited by Jeff_Jeske; December 17, 2004, 10:18 AM.
JJM CUSTOM TUNE /// ETS FMIC /// HKS TBE EXHAUST /// BBK TURBO /// OHLINS COILOVERS /// FIC 1100 INJECTORS
www.BOOSTEDFILMS.com
MY CAR DOMAIN
Originally posted by Jeff_JeskeBTW - we are gear limited not drag limited. According to GPS I got my 96 up to 143MPH ground speed before I ran out of gear....the car was still wanted to go though.
When heading into the wind, that could bring the aerodynamic speep limit lower right? simulating a slightly higher speed, increaseing lift. Physics know it alls, help me out here.Matt Hicks
Silver 97 2.0 Turbo
Factory Green ZX6RR
If you have 1,000 posts and have not donated to PT, you should consider doing so.
"We're all still learning."
More about gearing.....I feel the stock gearing is nearly perfect....1st is low enough to provide plenty of umph off the line even with very sticky tires. 2nd is tall enough to use a hefty dose of nitrous in and really get the stretch its legs before making the two shorter shifts. For what its worth I found short shifting first and hitting nitrous early the best route to take. You really dont want to shorten 2nd gear because you will be traveling slow when you make your 2-3 shift and it will cost you more time. You see the faster you are going when you make a shift the less time you lose because you cover more ground.MazdaSPEED6
I have to agree with pgt95. Even people rebuilding or just replacing their tranny, it would be a beneficial gear change, especially on a stock probe. I love the fact that my friends' prelude has such short gear ratios. He pulls really hard due to it.'93 Black on Black with Black Leather GT
PARTING OUT PROBE
Parting Out Probe
18"x8" SSR GT1 with Tires 4 Sale
drive an mx3...it has shorter gearing than my friends type-r.
the smaller diameter wheels/tires compared to the probe make a helluva difference.Wil (admin iMazda.com) 93' MX-ZE
Mods: ZE w/31 cams & curved-neck mani, 67mm t/b, obx headers w/2.5" straight-thru, 3" custom CAI,
Mazdaspeed mounts, Tochigi Fuji Sangyo 2-way LSD, ACT clutch, Noble Green Metallic paint, E-spec headlights,
OEM skirts, 16" SubZeros on Azenis, Tokico w/Eibach's, Mazdaspeed TTL & Bushing Kit, New OEM Leather seats & SE interior
READ THE HEADER FAQ OR DO A SEARCH
I'm looking more toward the daily driven and road racing/Auto-X guys rather than the Drag racing guys by needing a lower 2nd and 3rd gear. I've noticed in my KLZE powered PGT that 2nd seems to be too high compared to 1st and then 3rd is just a little bit higher than 2nd. It would be really nice In my opinion to have a lower 2nd if anything.I have no goals in Life and this is what I was told... "Even if it be something as simple as shooting a paintball gun from the top of the big green Bank of America building in Dallas trying to hit a honda prelude in the middle of the day, then do it" Quoted by Silent_Hill_3
RIP--) 1995 PGT Lazer red KLZE powered... Check it out at: http://www.cardomain.com/id/dubbed23
Originally posted by pgt95sweet, lets us know total cost for thep arts that fit playa, you ought to see if you can get a bulk discounti f this works and run a tranny rebuild BB!
This looks to be a very productive thread. I need to replace my tranny soon too, anyway, so maybe the info in here will help me build somethig really nice. Right now my 3rd gear and synchro are near shot and my 1-2 shift is getting worse, so i need something in the near future.
Keep the good stuff coming!
~Andy~
Does anyone know off hand what the trans code is for the 2.0? or where I could find the code? Someone said that 2.5 and 2.0 inards are swapable, if thats the case then I would think that anything that works for the 2.5 would work in a 2.0 and vise versa, EI new protege trans or MS protege with LSD.Matt Hicks
Silver 97 2.0 Turbo
Factory Green ZX6RR
Originally posted by M.HicksDoes anyone know off hand what the trans code is for the 2.0? or where I could find the code? Someone said that 2.5 and 2.0 inards are swapable, if thats the case then I would think that anything that works for the 2.5 would work in a 2.0 and vise versa, EI new protege trans or MS protege with LSD.
I was under the impression that they are both g series trannies so yes, anything that works for the 2.5 tranny will work for the 2.0.94 MX3 V6 - 403 whp 412 ft lbs 15 psi pump gas. RIP
04 Volvo S60R 6 spd
Is there the possibility of investing the time into a 1/4" adapter plate to use the straight MTX75 on the KL03 and have the beefier case benefit? I have seen many plates forsale for rearwheel drive cars as well as honda fwd cars, so why not the probe? From what I have heard in the past you need to space out the flywheel the same thickness as the adapter plate and "most" cv shafts have enough play that they will soak up the offset.1994 PGT MS2 LC-1 370cc 190lph KLZE intake ported heads Turbonetics T4 2.5" Magnaflow STS MX3 flywheel ceramic clutch, 355fwhp ** sold
1980 Fairmont 4-door, S472, Megasquirt, 351C, 678rwhp.
2003 Mach 1, FR500 engine, 372rwhp w/out spray.
2003 Escape, slow.
Originally posted by rurocknIs there the possibility of investing the time into a 1/4" adapter plate to use the straight MTX75 on the KL03 and have the beefier case benefit? I have seen many plates forsale for rearwheel drive cars as well as honda fwd cars, so why not the probe? From what I have heard in the past you need to space out the flywheel the same thickness as the adapter plate and "most" cv shafts have enough play that they will soak up the offset.MazdaSPEED6
