Ultimate 2.0 Mod Database
If you have any additions you believe should be added to the list please PM myself of PurpleMetal1 and we will get it added. currently the database is in the works, it may take me a couple of days to completely finish it so stay tuned.
Engine
• Header, Catback Exhausts and Hi Flow Catalytic Converters
• Camshafts, Adj. Cam Gears, Valve Springs, and head/main hardware
• Intakes, ThermaBlok Spacers, and Intake Manifold
• Ignition Control Units, Wires and Underdrive Pulleys
• Fuel Pumps, Fuel Pressure Regulators, and Nitrous kits
• Engines and Rebuild Kits
• Pistons, Rods, and Oil Pumps
Transmission
• Clutches Part 1
• Clutches Part 2 and Flywheels
• Engine Mounts/Inserts, Clutch Lines and Short Throw Shifters
Suspension
• Strut/Coilover Packages
• Strut and Coilovers
• Springs
• Swaybars, Trailing Links, Camber Plates, Front/Rear Strut Tower Bars and Control Arm Bushings
Cooling
• Radiators, Radiator Hoses and Radiator Caps
Brakes
• Big Brake Kits and Brake Pads
• Brake Pads Continued
Forced Induction
• Turbo Kits and Accessories
