HowTo - FogLights with no OEM Brackets
  • HowTo - FogLights with no OEM Brackets
    Hello Everyone, this is my car .
    As you can see my car only has 1 OEM foglight and it's not that good. So I went to autozone and bought some new foglights and decided to make a simple HowTo for all people that are like me.
    Experience: NONE what so ever!
    *I've never done this kind of work before, I'm a noobie here
    Tools:
    1) FogLights: mine are the Pilot PL-2055C -
    ***This is so you guys know how much it costs and where to get them.
    2) Circuit tester -
    3) Electrical tape
    4) Screwdriver
    5) Female Bullet Terminals -
    6) Ruler Set -
    7) Driller
    Ok so let's begin.
    This are all the parts that came with the foglights.
    Installation:
    1) Check the cables, which one is positive and which one is negative. Example: In my car the driver side foglight cables where like this:
    and the passenger side foglight cables where like this:
    Took the passenger side OEM foglight out:
    2) Unplug the Negative battery cable, then connect the new foglight to the cables just to test that everything works. Connect back the Negative battery cable and test the foglight:
    ***Just so you know, I'm not leaving it like that, like I said just testing the equipment and holding the cables so they don't touch each other.
    3) Now I'm gonna use this to set where I'm gonna put the foglights:
    This is how I ended on one side:
    and the other:
    ***The only reason I used that degree ruler was because I wanted to know if I was properly aiming the lights to a 90 degree. The lines represent each side of the new brackets of the foglights, the two ovals represent where the I'll make the little holes and put the bracket screws. The line at the top represents that I'm properly aiming at a 90 degree look, so lights are properly aim forward and not sideways:
    ***Some more examples:
    4) Made the little holes with my driller and mounted the brackets, then mounted the foglight:
    5) Make the arrangements to set the foglights at least 5 to 10 degrees down so that the lights are properly aimed in the vertical axis:
    ***Some more Pics:
    6) With the Negative battery cable unplug, apply the female bullet terminals to the car cables, after that connect the new foglight to the cables:
    ***Test to make sure everything works properly:
    7) Use the electrical tape to make sure no dust, water, or whatever thing make contact with the cable and that the positive cable doesn't touch the negative cable. After that it's a thing of putting a little bit of more tape on the hole thing and hide the cables behind the bumper.
    YOUR DONE!
    EXPERIENCE GAINED: 218
    YOU'VE LEVEL UP! 1 -> 2
    ABILITIES GAIN: ELECTRIC TESTING: MAKE USE OF THIS ABILITY TO MAKE SURE WHICH WIRE IS WHICH.
    For my case as the sun was going down:
    I began testing them and here is the finish look:
    I really had fun mounting the new foglights and thinking of whats my next project.
    ***Please leave your comments and ideas and rate my little build,
    1993 | White | Ford | Probe | GT
    for i (i = 160hp, i >= otherCar, i = )
    {cout << "" << endl; }
    if (i < otherCar)
    {cout << << endl;}
    they look pretty good, what kind of headlights are you using?
    97 pgt, manual swap, jdm lsd trans, cm stage 2 clutch, mx3 flywheel, cai
    2001 626
      Briefly looked over it, but great job
      G35 Coupe
      95PGT kinda stock
      12 R6
      14' Optima slow
        i've seen a few probes that people have done this mod to. good to finally see a write-up for those cars that don't have OEM foglights.
        on a personal note, i've used the pilot foglights mounted in the stock brackets on my 93pgt for years. still look good and only occasionally needs replacing [due to broken lenses].
        oh, and moved to the How To forum.
        Let's get DANGEROUS!
          Lookin' good!
          I did a very similar install a couple of years ago. You were much more precise whereas I eyeballed it. These lights look very close to the stock fog lights even without the OEM brackets. (Neither the OEM fog lights nor the OEM brackets were on my car when I got it, but it had some non-working, cheap, round, glued-on replacements instead.)
          '97 GTS 5M no stripes, no spoiler;
          '93/'94 rear bumper, side mirrors, tail lights
          MX-6 front seats
          MX-6 steering wheel w/626 cruise controls
            Nice info thanks
              my stock fogs are really dull and foggy so I might be doing this mod on my nxt day off
                Sure wish the pictures for this thread were still hosted and available for viewing.
                Registered Probetalk Member #392.
                Co-founder of ALPOC. Formerly had '93 Rio Red GT, PRD STS-99, Bosch H4 lamps, Borla, Pilot 1055-c driving lamps. IT'S CRUNCHY!
                '93 Teal PGT. '94 black PSE. '91 PLX, 300k+ miles.
                  Theres gonna be a LOT of that unfortunately because photobucket got greedy and doesnt allow 3rd party hosting without a paid membership now.
                  Jim K.
                  :89LX: Gone but not forgotten:96 PGT:(ze twin turbo) Its not purple dammit! Its BOYSENBERRY! :89PGT: New project :03 KLZE Protege5: Daily When I go for a drive, I leave life behind. Friends, work, everything. Its just me, the car, and a twisty road. The exhilaration of being on the edge of catastrophe is something that I will never be able to give up.
                    Photobucket was always an issue for me. Still to this day don’t understand why it’s used.
                    Never was able to view any of the links.
                    Supermotors May have a watermark but it’s free and has stored my pics for 20years.
                    1993 Mercury tRacer :Vitara & mFactory: In progress 2020
                    2014 Factory Five 818s: sold
