Old September 23rd, 2017, 03:01 PM   #1
shdtree95
Aftermarket Mechanical Water Temp gauge
So I bought a SuperPro Mechanical Water Temp gauge to install in my 95 Ford Probe Gt to run until I swap out my gauge cluster. The probe/sender on this gauge is roughly 1/2" and the threaded fitting maybe 14mm-16mm. The factory port on the intake is 10mm with a fine thread. Has anyone done this and had luck finding an NPT adapter to make such a gauge work?
Joe
my email address is NOT working!
shdtree95 is offline   Reply With Quote
Old September 23rd, 2017, 05:25 PM   #2
I think it's not a metric or standard thread, I remember reading that somewhere. Anyone else know.
Old September 23rd, 2017, 07:38 PM   #3
LowClassCC
Fazda Tuning
LowClassCC's Avatar
Planning to hook mine up soon. Sorry I can not be any help for now.
LowClassCC is offline   Reply With Quote
Old September 23rd, 2017, 08:35 PM   #4
ZE-Infused
I used an electric automer gauge. The sender that came with mine threaded right in.
95 PGT
07 MS6
ZE-Infused is offline   Reply With Quote
Old September 25th, 2017, 05:34 PM   #5
shdtree95
Mechanical Water Temp solution
Found the Autometer 2282 for 1" 11/4" hose with 3/8" bung as as inline temp radiator hose gauge adapter.
FS: VDO Water Temp, Oil Temp & Boost gauge probesport_gt PT Member Sales 2 May 23rd, 2006 03:50 PM
FS: Autometer carbon fiber mechanical oil temp gauge bemidjipenny PT Member Sales 2 April 27th, 2006 04:24 PM
Coolant temp gauge stopped working. Anyone install an aftermarket temperature gauge? strudor 2nd Gen (93-97) V6 2.5L 6 August 11th, 2005 06:28 PM
F/S::::Aftermarket Shifter, A/F Gauge , Water Temp gauge, Venom400 97pGT PT Member Sales 17 June 15th, 2003 12:59 PM
Is water temp the same thing as engine temp ??? URXTASY 2nd Gen (93-97) V6 2.5L 4 June 6th, 2001 01:08 PM
