Old March 11th, 2011, 02:34 PM   #1
dmfarms
1993/1994 Wiring Diagrams
Wire Color Code Identification
BK : Black
BL : Blue
BR : Brown
DB : Dark Blue
DG : Dark Green
GY : Gray
GN : Green
LB : Light Blue
LG : Light Green
PK : Pink
O : Orange
P : Purple
R : Red
T : Tan
V : Violet
W : White
Y : Yellow
Where two colors are shown for a wire, first is basic color and second is stripe marking (tracer).
For example, BR/O is brown with orange stripe
Diagram Information and Instructions
http://i279.photobucket.com/albums/k...icSymbols2.gif
http://i279.photobucket.com/albums/k...ticSymbols.gif
http://i279.photobucket.com/albums/k...tification.gif
Air Bag Systems
http://i279.photobucket.com/albums/k...ingCircuit.gif
http://i279.photobucket.com/albums/k...ngCircuit2.gif
http://i279.photobucket.com/albums/k...ngCircuit3.gif
Radio (Power Antenna)
http://i279.photobucket.com/albums/k...werAntenna.gif
Antilock Brakes / Traction Control Systems
http://i279.photobucket.com/albums/k...nformation.gif
http://i279.photobucket.com/albums/k...formation2.gif
http://i279.photobucket.com/albums/k...formation3.gif
http://i279.photobucket.com/albums/k...formation4.gif
http://i279.photobucket.com/albums/k...formation5.gif
http://i279.photobucket.com/albums/k...formation6.gif
Antitheft and Alarm Systems
Charging System
Cruise Control
http://i279.photobucket.com/albums/k...iseControl.gif
http://i279.photobucket.com/albums/k...seControl2.gif
Rear Window Defrost/Heated Mirrors
http://i279.photobucket.com/albums/k...tedMirrors.gif
Heating and Air Conditioning
http://i279.photobucket.com/albums/k...ing/Heater.gif
http://i279.photobucket.com/albums/k...ng/Heater2.gif
http://i279.photobucket.com/albums/k...semblyHVAC.gif
http://i279.photobucket.com/albums/k...withHeater.gif
http://i279.photobucket.com/albums/k...ithHeater2.gif
http://i279.photobucket.com/albums/k...ithHeater3.gif
Instrument Panel, Gauges and Warning Indicators
[COLOR="Red"] Instrument Cluster
http://i279.photobucket.com/albums/k...entCluster.gif
http://i279.photobucket.com/albums/k...ntCluster2.gif
http://i279.photobucket.com/albums/k...ntCluster3.gif
http://i279.photobucket.com/albums/k...ntCluster4.gif
http://i279.photobucket.com/albums/k...ntCluster5.gif
http://i279.photobucket.com/albums/k...ntCluster6.gif
Instrument Illumination
http://i279.photobucket.com/albums/k...lumination.gif
http://i279.photobucket.com/albums/k...umination2.gif
http://i279.photobucket.com/albums/k...umination3.gif
Audible Warning Device Warning Chime
http://i279.photobucket.com/albums/k...rningChime.gif
http://i279.photobucket.com/albums/k...ningChime2.gif
dmfarms is offline   Reply With Quote
Old March 11th, 2011, 02:34 PM   #2
dmfarms
Horn/Cigar Lighter
http://i279.photobucket.com/albums/k...garLighter.gif
Exterior Lamps
http://i279.photobucket.com/albums/k...eriorLamps.gif
http://i279.photobucket.com/albums/k...riorLamps2.gif
Backup Lamp
http://i279.photobucket.com/albums/k...BackupLamp.gif
Turn/Hazard/Stop Lamps
http://i279.photobucket.com/albums/k...dStopLamps.gif
http://i279.photobucket.com/albums/k...StopLamps2.gif
http://i279.photobucket.com/albums/k...StopLamps3.gif
Courtesy Lamp
http://i279.photobucket.com/albums/k...urtesyLamp.gif
http://i279.photobucket.com/albums/k...rtesyLamp2.gif
Daytime Running Lamp
http://i279.photobucket.com/albums/k...unningLamp.gif
http://i279.photobucket.com/albums/k...nningLamp2.gif
http://i279.photobucket.com/albums/k...nningLamp3.gif
Fog/Driving Lamp
http://i279.photobucket.com/albums/k...rivingLamp.gif
http://i279.photobucket.com/albums/k...ivingLamp2.gif
Hazard Warning Lamps
http://i279.photobucket.com/albums/k...rningLamps.gif
http://i279.photobucket.com/albums/k...ningLamps2.gif
http://i279.photobucket.com/albums/k...ningLamps3.gif
http://i279.photobucket.com/albums/k...ningLamps4.gif
Headlamp
http://i279.photobucket.com/albums/k...g/Headlamp.gif
http://i279.photobucket.com/albums/k.../Headlamp2.gif
http://i279.photobucket.com/albums/k...lampswitch.gif
Power Mirrors
http://i279.photobucket.com/albums/k...werMirrors.gif
Power Door Lock Control Module
With Keyless entry
http://i279.photobucket.com/albums/k...ylessEntry.gif
http://i279.photobucket.com/albums/k...lessEntry2.gif
Without Keyless entry
http://i279.photobucket.com/albums/k...lockmodule.gif
Old March 11th, 2011, 02:35 PM   #3
dmfarms
Powertrain Management Information
DISTRIBUTOR, FPRC SOLENOID VALVE, PCM POWER RELAY
http://i279.photobucket.com/albums/k...LMODULEPCM.gif
FUEL INJECTORS, JOINT CONNECTOR, KNOCK SENSOR
http://i279.photobucket.com/albums/k...NOCKSENSOR.gif
CANISTER PURGE SOLENOID (CANP), EGR SOLENOID VALVE (VENT), EGR SOLENOID VALVE (VACUUM), LEFT HEATED OXYGEN SENSOR (HO2S)
http://i279.photobucket.com/albums/k...SENSORHO2S.gif
IDLE AIR CONTROL SOLENOID VALVE (IAC), POWER STEERING PRESSURE SWITCH, RIGHT HEATED OXYGEN SENSOR (HO2S), VRIS SOLENOID VALVE #1, VRIS SOLENOID VALVE #2
http://i279.photobucket.com/albums/k...ISSOLENOID.gif
CRANKSHAFT POSITION SENSOR, ENGINE COOLANT TEMPERATURE SENSOR (ECT), ENGINE COOLANT TEMPERATURE SENSOR (COOLING FAN), MALFUNCTION INDICATOR LAMP, TRANSAXLE CONTROL MODULE
http://i279.photobucket.com/albums/k...NCONTROLMO.gif
DATA LINK CONNECTOR, FUEL PUMP/FUEL GAUGE SENDER, FUEL PUMP RELAY, INERTIA FUEL SHUTOFF SWITCH
http://i279.photobucket.com/albums/k...TOFFSWITCH.gif
CLUTCH PEDAL POSITION SWITCH, PARK/NEUTRAL POSITION SWITCH, TRANSAXLE CONTROL MODULE (TCM), VOLUME AIR FLOW SENSOR (VAF)
http://i279.photobucket.com/albums/k...WSENSORVAF.gif
EGR VALVE POSITION SENSOR, THROTTLE POSITION SENSOR (TPS), TRANSAXLE CONTROL MODULE (TCM)
http://i279.photobucket.com/albums/k...LMODULETCM.gif
Radiator Cooling Fan Motor
http://i279.photobucket.com/albums/k...ngFanMotor.gif
Radio/Stereo
http://i279.photobucket.com/albums/k...adioStereo.gif
Radio (Premium Sound)
http://i279.photobucket.com/albums/k...emiumSound.gif
http://i279.photobucket.com/albums/k...miumSound2.gif
Radio (Premium Sound With CD Player And Subwoofer)
http://i279.photobucket.com/albums/k...dSubwoofer.gif
http://i279.photobucket.com/albums/k...Subwoofer2.gif
With CD Player and Graphic Equalizer
http://i279.photobucket.com/albums/k...cEqualizer.gif
http://i279.photobucket.com/albums/k...Equalizer2.gif
With Graphic Equalizer
http://i279.photobucket.com/albums/k...WGraphicEq.gif
http://i279.photobucket.com/albums/k...GraphicEq2.gif
Power Lumbar Seats
http://i279.photobucket.com/albums/k...umbarSeats.gif
Power Seats
http://i279.photobucket.com/albums/k.../PowerSeat.gif
Shift Interlock, A/T
http://i279.photobucket.com/albums/k...tInterlock.gif
Starting System Manual Transaxle
http://i279.photobucket.com/albums/k...lTransaxle.gif
Starting System Automatic Transaxle
http://i279.photobucket.com/albums/k...cTransaxle.gif
Ignition Switch
http://i279.photobucket.com/albums/k...tionSwitch.gif
Power Moonroof
http://i279.photobucket.com/albums/k...erMoonroof.gif
Automatic Transmission Control Systems
http://i279.photobucket.com/albums/k...rolSystems.gif
http://i279.photobucket.com/albums/k...olSystems2.gif
http://i279.photobucket.com/albums/k...olSystems3.gif
Transmission Position Switch/Sensor, A/T
http://i279.photobucket.com/albums/k...chSensorAT.jpg
http://i279.photobucket.com/albums/k...hSensorAT2.jpg
http://i279.photobucket.com/albums/k...hSensorAT3.jpg
http://i279.photobucket.com/albums/k...hSensorAT4.jpg
http://i279.photobucket.com/albums/k...hSensorAT5.jpg
Power Window
http://i279.photobucket.com/albums/k...owerWindow.gif
Wiper and Washer Systems
Interval Wiper/Washer
http://i279.photobucket.com/albums/k...iperWasher.gif
Non-Interval Wiper/Washer
http://i279.photobucket.com/albums/k...ervalWiper.gif
Liftgate Wiper
http://i279.photobucket.com/albums/k...tgateWiper.gif
Old March 11th, 2011, 06:05 PM   #4
Joe Kamman
Good info. I have the manual with this in it, but wished we had something on-line for when I'm not close to the manual.
Probably should be a sticky
'94 Rio Red GT, 2.65l, 8.8:1 CR, Eaton M90, Quaife limited slip, TEC GT, 370 cc's (Still have the short block, all else gone)
'98 Pearl White 3000GT VR4 (with a few mods) SOLD
'93 Bone Stock MX-6 Sold (in '05) sadly to the crusher in 2010
'92 Midnight Blue Porsche 968
Joe Kamman is offline   Reply With Quote
Old March 11th, 2011, 07:14 PM   #5
dmfarms
figured it might help out someone that didnt have it, plus you can print just what you need and throw it away when youre done
Old March 24th, 2011, 07:40 PM   #6
Eli 94 PGT
everything and some! nice.
KLZE '94 PGT. CAI, 2 chamber catback FLOWMASTER, 17" Motegi 5 spoke, Exedy stage 2 clutch, Sleepy eyes, mazda 6 brakes, and xtremethings ecu. 9 voice speakers all with 50 watts each.
Eli 94 PGT is offline   Reply With Quote
Old April 6th, 2011, 07:17 AM   #7
dmfarms
any other diagrams you need, just ask, I will try and put them up
Old April 6th, 2011, 07:38 AM   #8
PaulG
What year of Probe are these diagrams for? Wire colors might differ based on year.
1997 MX-6 LS
PaulG is offline   Reply With Quote
Old April 6th, 2011, 07:55 AM   #9
dmfarms
lol my bad...93~94
Old April 29th, 2011, 06:26 PM   #10
Nightmare
Definitely should be a sticky.
2003 MSP KLDE-T. #705
Nightmare is offline   Reply With Quote
Old September 17th, 2014, 01:44 PM   #11
Dan [Sac]
Admiral General
Dan [Sac]'s Avatar
Better late than never. Found this thread using Google while hunting down the horn circuit for Probes....
- KLZE, fender-flared, right hand drive, 2350 lb fully loaded sex machine. ||
||- SOLD
93 PGT
- 10.24 @ 139.9 mph ||545 whp @ 20 psi ||
- GONE
97 GTS - Rear Wheel Drive KLZE, 6-speed, 3.90 Torsen LSD, 2650 lb, daily driver! -
- GONE
Dan [Sac] is offline   Reply With Quote
1993 mx6 2.0L mazda ecu wiring diagrams FLMX-6 2nd Gen (93-97) I4 2.0L Performance 2 December 28th, 2012 09:22 PM
Wiring Diagrams spokane89lx 1st Gen (89-92) All 1 April 2nd, 2007 09:22 PM
1993 PGT Engine/Disty/ECU pinout wiring diagrams. Silver_Bullit 2nd Gen (93-97) V6 2.5L Archive 2 March 19th, 2004 06:04 PM
Wiring diagrams PLEASE rodrigo Car Audio And Electronics 1 March 22nd, 2002 06:52 PM
Wiring diagrams shad420w 2nd Gen (93-97) V6 2.5L 0 September 30th, 2001 07:26 PM
