Old September 4th, 2017, 07:21 PM   #1
P1P
2.5L KL Torque Specs
Maybe this will help some of you out that have current or future builds going on. Not sure is this has been posted before but I was bored and the site has been lacking activity lately
2.5L KL Torque Specifications
(According to Ford Service Manual)
Description - N/m - Lb/Ft - Lb/In
Oil Pan Drainplug - 29-41 - 22-30 - N/A
A/C and Generator Tensioner Lower Bolt - 19-25 - 14-18 - N/A
Crankshaft Damper Bolt - 157-166 - 116-122 - N/A
Timing Belt Cover Bolts - 8-10 - N/A - 71-88
A/C and Generator Tensioner Upper Bolt - 19-25 - 14-18 - N/A
Oil Dipstick Bolt - 8-10 - N/A - 71-88
Water Pump Pulley Bolts - 8-10 - N/A - 71-88
Auto Belt Tensioner Bolts - 19-25 - 14-18 - N/A
RH Engine Mount Nuts - 74-103 - 54-76 - N/A
RH Engine Mount Through Bolt - 67-93 - 50-68 - N/A
Water Pump Bolts - 19-25 - 14-18 - N/A
Oil Pan Bolts (large) - 19-25 - 14-18 - N/A
Oil Pan Bolts (small) - 8-10 - N/A - 71-88
Converter Inlet Pipe Nuts - 40-55 - 30-41 - N/A
Oil Pump Bolts - 19-25 - 14-18 - N/A
Power Steering Belt Tensioner Upper Bolt - 32-46 - 24-33 - N/A
Power Steering Pump Rear Bracket Bolt - 32-46 - 24-33 - N/A
Power Steering Belt Tensioner Lower Bolt - 19-25 - 14-18 - N/A
A/C Compressor Bracket-to-Engine Block Bolts - 38-51 - 28-38 - N/A
A/C Compressor-to-Bracket Bolts - 38-51 - 28-38 - N/A
Oil Strainer Bolts - 8-10 - N/A - 71-88
Oil Filter Body Bolts - 19-25 - 14-18 - N/A
Oil Cooler Shield Bolts - 8-10 - N/A - 71-88
Oil Pressure Switch - 12-17 - N/A - 104-156
Oil Cooler Nut - 25-34 - 19-25 - N/A
Oil Baffle Bolts - 19-25 - 14-18 - N/A
Fuel Rail-to-Intake Manifold Bolts - 19-25 - 14-18 - N/A
Fuel Supply and Return Line Bracket Bolts - 8-10 - N/A - 71-88
Intake Manifold Nuts and Bolts - 19-25 - 14-18 - N/A
Cylinder Head Cover Bolts - 5-8 - N/A - 44-78
Camshaft Cap Bolts - 11-14 - 8-10 - N/A
Camshaft Pulley Lock Bolts - 123-140 - 90-103 - N/A
Exhaust Manifold Insulator Bolts - 8-10 - N/A - 71-88
Exhaust Manifold Nuts and Bolts - 19-25 - 14-18 - N/A
Cylinder Head Bolts - 23-26 - 17-19 - N/A
Flywheel Bolts - 61-67 - 45-49 - N/A
Pressure Plate Bolts - 18-26 - 14-19 - N/A
Flex Plate Bolts - 61-68 - 45-50 - N/A
Rear Engine Mount Nuts - 67-93 - 50-68 - N/A
Rear Engine Mount Through Bolt - 86-116 - 63-86 - N/A
Front Engine Mount Nuts - 74-102 - 55-75 - N/A
Front Engine Mount Through Bolt - 86-116 - 63-86 - N/A
LH Engine Mount Nuts - 75-104 - 55-77 - N/A
LH Engine Mount Through Bolt - 86-116 - 63-86 - N/A
RH Engine Mount Nuts - 74-103 - 55-77 - N/A
Power Steering Pump Mounting Bolts - 31-46 - 23-34 - N/A
Extension Bar Nut (MTX) - 32-46 - 22-33 - N/A
Transaxle Shift Linkage Bolt (MTX) - 16-22 - 12-16 - N/A
Transaxle Cradle Nuts and Bolts (front mount) - 75-104 - 55-77 - N/A
Transaxle Cradle Nuts and Bolts (front and back) - 67-93 - 50-68- N/A
Transaxle Cradle Nuts and Bolts (vibration dampener) - 44-60 - 32-44 - N/A
Transverse (cross) Member Mounting Bolts - 94-126 - 69-93 - N/A
Splash Shield Bolts - 8-10 - N/A - 71-88
Wheel Lug Nuts - 89-117 - 66-86 - N/A
Fuel Rail Supply Line - 25-34 - 18-25 - N/A
Radiator Hold-Down Bolts - 8-10 - N/A - 71-88
Engine-To-Transaxle Bolts - 68-99 - 50-73 - N/A
Cooling Fan Relay Bracket Bolts - 8-10 - N/A - 71-88
Fuel Filter Nuts - 8-10 - N/A - 71-88
Fuel Line Bracket Bolts - 8-10 - N/A - 71-88
Power Steering Hose Bracket-To-Power Steering Pump Bolt - 31-46 - 23-34 - N/A
Oil Jets - 3-4 - N/A - 27-43
Crankshaft Cap Bolts - 23-25 - 17-19 - N/A
Lower Cylinder Block Bolts - 19-22 - 14-16 - N/A
Connecting Rod Cap Bolts - 22-27 - 16-19 - N/A
Knock Sensor - 20-34 - 15-25 - N/A
Valley Cover Bolts - 8-10 - N/A - 71-88
Thermostat Housing Bolts - 19-25 - 14-18 - N/A
Water Pipe Bolt - 19-25 - 14-18 - N/A
Coolant Elbow Bolts - 19-25 - 14-18 - N/A
Seal Plate Bolts - 8-10 - N/A - 71-88
No.1 Idler Pulley Bolt - 34-52 - 25-38 - N/A
No.2 Idler Pulley Bolt - 37-52 - 27-38 - N/A
Auto Belt Tensioner Pulley Bolt - 37-44 - 27-33 - N/A
Engine Mounting Bracket Bolts - 43-61 - 32-45 - N/A
Crankshaft Position (CKP) Sensor Bolts - 8-10 - N/A - 71-88
Spark Plugs - 15-22 - 11-16 - N/A
Front Lifting Eye Bolt - 19-25 - 14-18 - N/A
Rear Lifting Eye Bolt - 38-51 - 28-38 - N/A
Distributor Bolts - 19-25 - 14-18 - N/A
A/C and Generator Belt Tensioner Bracket Bolts - 19-25 - 14-18 - N/A
Generator Bolts - 37-52 - 27-38 - N/A
Oil Pump Cover Bolts - 6-9 - N/A - 52-78
Old September 5th, 2017, 01:05 AM   #2
fordprobegt67
nice i deff need this info thanks
95 PGT Current project
95 PSE swapped in 93 KL...Headers.... K&N cold Air.... Gutted Caged and ready for Dirt
01 Seabring Convert 01 Neon Rims With Spacers..
99 Olds Cutlas DD
fordprobegt67 is offline   Reply With Quote
Old September 5th, 2017, 05:58 AM   #3
pek32132
specs
thank you much needed
pek32132 is offline   Reply With Quote
Old September 5th, 2017, 08:35 AM   #4
P1P
---------- Post added at 02:35 PM ---------- Previous post was at 02:34 PM ----------
maybe some mod can make this a sticky
Old September 5th, 2017, 10:00 AM   #5
Makes it convenient to have them all listed in one place rather than trying to go from section to section in the shop manual to find all of the specs -since they are not all grouped together in one section.
P.S. Don't forget to add the additional (2x) 90 deg turns on girdle bolts and head bolts etc.
Old September 6th, 2017, 06:58 AM   #6
Greg 94 PGT
Greg 94 PGT's Avatar
Nice, this does make it easier to have all in one spot.
Good thinking
379whp @ 20lbs *Sold*
Greg 94 PGT is offline   Reply With Quote
Rod bolt torque specs, rod journal specs Anyone? short4stuff 2nd Gen (93-97) V6 2.5L 1 October 23rd, 2013 08:30 PM
Bolt Torque Specs cwanamaker 2nd Gen (93-97) V6 2.5L 6 November 7th, 2001 10:19 AM
torque wrench specs? b4tn 2nd Gen (93-97) V6 2.5L Performance 3 October 21st, 2001 03:34 PM
Torque specs 93ProbeSE 2nd Gen (93-97) I4 2.0L 1 October 3rd, 2001 02:45 PM
torque specs krisw 2nd Gen (93-97) V6 2.5L 1 August 29th, 2001 09:33 PM
