Go Back   ProbeTalk.com Forums > General > Knowledge Base > Appearance Section
Appearance Section Talk about appearance modifications here.
Old August 16th, 2017, 08:57 PM   #1
g98swc
Spoiler Hardware
I recently picked up a spoiler from a JY that I am going to refurbish, but it needs new rubber seals and hardware. I have had a hell of a time finding a spoiler hardware kit, so i figured I would ask if anyone knows of a place to get one.
g98swc is offline   Reply With Quote
Old August 28th, 2017, 01:03 PM   #2
g98swc
Since no one responded, I just made new seals of neoprene rubber. I see the access hole for one of the bolts on the underside of the hatch for each side, but not the other. Does the other one not need an access and only goes through one layer of sheet metal? Its a factory spoiler, so does anyone have a pic of the underside if the lid?
Old August 28th, 2017, 02:02 PM   #3
What do you mean the other? Which spoiler do you have? I have a 3 piece and a 1 piece that bolts down in 2 places. The 3 piece ends have a thin sticky double sided foam to attach them to the car. Those pieces did not want to let go when I took them off, actually creased the sheetmetal.
BLUEnoEQ is online now   Reply With Quote
Old August 28th, 2017, 05:04 PM   #4
g98swc
I have a 1 piece with two holes on each post from a 93 and when I remove the plastic on my 94, the lid only has one access bulge/hole in the sheet metal on each side to access the bolt heads.
Old August 28th, 2017, 06:29 PM   #5
fordprobegt67
ill take a pic of mine tomorrow after i get home and show you.
95 PGT Current project
95 PSE swapped in 93 KL...Headers.... K&N cold Air.... Gutted Caged and ready for Dirt
01 Seabring Convert 01 Neon Rims With Spacers..
99 Olds Cutlas DD
fordprobegt67 is offline   Reply With Quote
Old August 28th, 2017, 06:43 PM   #6
g98swc
Thank you. I'm guessing they may have changed it in '94, but I'm pretty sure the JY '93 I pulled it off had 2 each.
Old September 1st, 2017, 09:28 PM   #7
fordprobegt67
Remove the rubber seals and both bolts are accessable ..
99 Olds Cutlas DD
SE Spoiler (vs) GT Spoiler (vs) No Spoiler Gunmetalfox Appearance Section 42 January 26th, 2013 03:01 PM
never put on, factory 95 style spoiler with new hardware and all 91PGT PT Member Sales 12 March 19th, 2003 11:54 PM
FS: Stock 1st gen Spoiler with Mounting Hardware Allen PT Member Sales 4 January 31st, 2002 11:06 PM
Spoiler Hardware... TurboSE Appearance Section 2 October 17th, 2001 05:11 PM
Hardware Store Discounts RICEKILLER PT Member Sales 4 June 22nd, 2001 09:51 AM
