Alarm and Remote Start Wiring Colors For A 90-92 Ford Probe
  • Alarm and Remote Start Wiring Colors For A 90-92 Ford Probe
    Alarm Colors
    Constant 12 volts : Black @ ignition switch harness
    Ignition 12 volts : Black/White @ ignition switch harness
    Starter : Black/Yellow @ ignition switch harness
    Dome Light : Red/Blue (-) @ courtesy light OR
    Red/White (-) @ Driver's Kick Panel
    Trunk Pin Switch : Red (-) @ cargo light or switch
    Parking Lamp : Red/Black (+) @ light switch
    Power lock : Green/Black @ Driver Kick Panel under Fuse Block
    Power Unlock : Same as lock but with an inline 4.7K ohm resistor
    Remote Start
    Tach Signal : Yellow/Blue @ Coil, Test Connector, or Dash Tach.
    Ignition #2 : Black/Red @ ignition switch harness
    Ignition #3 : N/A
    Acccessory : Blue @ Ignition Switch Harness
    Neutral Safety : Not grounding type (-) : OEM switch opens starter circuit
    Brake Light : White/Green (+) @ switch above brake pedal
    Reverse Light : Red/Green (+) @ switch
    OEM Horn : Green/Orange @ Steering column harness
    Headlights : White/Yellow (-) @ headlight switch
    Enjoy
