MSD adapter
  • MSD adapter
    Does anyone know if there is an adapter for the MSD 6a for the 2.5L? I installed one in a friend's probe and we had to tear apart the distributor and cut a metal strip and solder a wire to it to attach to a different location. Anyway, I am going to put an MSD on my 2nd gen PGT and I'd like to avoid surgery on the distributor. Can anyone give advice?
    -john
    yeah.....I wish....I think you're pretty much screwed....you have to do all that bullshit. :x
    www.probe-gt.com
    Minnesota Probe Owners Club
    15.443@90.44
      cripes!! It just seems like there would be a NORMAL way to install this thing
        i know
        I'm going to do this soon. maybe......
        www.probe-gt.com
        15.443@90.44
          Nope, stock cap must be modified...
          2015 Audi Q3 - Stock |
            yeah....doesn't the idea of cutting up your distributor and gluing a post in the hole sound just great? well, I guess it would be pretty nice when it was all done.
            www.probe-gt.com
            15.443@90.44
              Say uhh... is there another set of install directions somewhere besides performanceprobe.com? The ones on that site call for using the internal coil rather than an external one. I'd kinda like to use an external one just for the heck of it.
              Ah well, Thanks..
                use a Klze cap..they had external coils.
                I believe someone is selling them in the bulk buy section
                take a look
                  take a look
                  The ZE cap will not fit. You need the ZE disty too.
                  I don't post here anymore.
                    I already have a modified 03 cap - is that all it takes? Wire up an external coil to it (pull out the internal coil? is it needed to support the rotor shaft at all?) and then use the same wiring diagram as seen on performanceprobe.com?
                      I think the internal coil is still required for the car to operate. But you are just jimmy rigging in an external coil that actually powers the spark.
                      www.probe-gt.com
                      15.443@90.44
