Go Back   ProbeTalk.com Forums > General > Probe Lounge
Probe Lounge Discussion about most everything Non Probe related goes here.
Old June 18th, 2017, 02:33 PM   #1
Hammerhead
Identify This Bolt
Found this bolt when I dropped the splash shield from under front right engine.
Can't find where it may have come from.
Looks important tho.
'94 Probe GT
http://s972.photobucket.com/user/Fly...icvpw.jpg.html
Thanks
Hammerhead is offline   Reply With Quote
Old June 18th, 2017, 04:32 PM   #2
'94 Probe GT
Thanks
I can't tell the exact size from the photo -but if it is a M6x1.0 bolt with integral washer -that would be one of your splash shield bolts. I believe on the bottom front that goes through plastic splash shield to metal threaded hole in center member -if I remember correctly. I can't remember 100% -because my plastic shields are off at the moment. But it does look like some of the bottom side hardware.
Old June 18th, 2017, 04:37 PM   #3
Intake manifold bolt? The threads look mashed so maybe it's been replaced. Another possibility is exhaust manifold bolt there should be 3 on the bottom 4 on the top, 3 are studs with a nut. You may have to feel around to confirm they're all in there. Is there any mysterious loss of power or idle fluctuations? Intake manifold should be 8 bolts and 4 nuts.
Old June 18th, 2017, 08:30 PM   #4
mac1
Probe has-been
mac1's Avatar
Doesn't look important at all
1993 Mercury Tracer : built KL and shit
Old June 19th, 2017, 12:52 PM   #5
J_Unit
Looks like the alternator bracket bolt. The car uses that style bolt in multiple places. But since the threads are chewed up like my alternator bracket bolt was, that's my guess.
Bolt on 93GT vs. Bolt on 94 Z28 1993fpgtatx Midwest Fords & Mazdas 2 May 19th, 2008 11:48 AM
Cam Pulley Bolt, Left or Right Hand Bolt? emalernee 2nd Gen (93-97) V6 2.5L 5 February 20th, 2005 12:57 PM
tbird sc for bolt on ? whats the best bolt on turbo for performance? Sphinx Munkey 1st Gen (89-92) Performance 10 November 21st, 2003 02:34 PM
7 bolt vs 5 bolt flange?? bjc26 Forced Induction (Turbo/S.C.) 10 October 4th, 2003 05:41 PM
