?'s on main bearing/gridle(cradle) bolts.
  • ?'s on main bearing/gridle(cradle) bolts.
    i am almost done rebuilding my kl03 and was wondering if we can reuse the 12 bolts that connect the gridle(cradle) to the block? thank you.
    service manual
    says...bolts longer than the following spec shoud be replaced.
    bolts marked
    A-138.5mm
    B-138.5mm
    C-121.0mm
    this is from under the cap to the end of the threaded part of the bolt. Not total length!
    Probe is now gone!
      thank you
        the guy putting the block together says he has only turned them 45 deg. and he feels like they are about to break. where could i buy a set of new ones? Besides mazda because they are 10.75 a piece. that over $130 for bolts
          yo g's was god in da hood
