Old April 12th, 2014, 05:17 AM   #51
Mud Flight
Gates T214RB $56.79 from RockAuto
Mud Flight is offline   Reply With Quote
Old April 15th, 2014, 01:04 AM   #52
Jollywonker
sweet.....
Jollywonker is offline   Reply With Quote
Old April 15th, 2014, 03:20 AM   #53
projectB10
thanks Terry ...the downer is the additional US$50 Post and Packaging cost to get it too NZ
Eunos Presso HI-XS Special Edition, KLZE, KL47 IM+TB, MX6 LSD box OEM front s/bar, Outlaw IM+TB thermalbloks, lightened K801 fly, XTD Stage 3 clutch & cover balanced to f/wheel, mbolin tranny saver , walbro 255,short shifter, SRD shifter bushings- H&R Springs and Koni inserts, MSpeed engine mounts, SS brake and clutch lines, PRM CAI,Whiteline rear strut and swaybar, 7x17 Konig/Maxxim Fourteen rims, and stuff.
projectB10 is offline   Reply With Quote
Old April 15th, 2014, 05:39 PM   #54
WhiteDart
WhiteDart's Avatar
So tuning has become a slight problem. lol. The new turbos as so efficient that the much higher airflow is causing a large lean condition at low rpm/throttle positions at partial boost. Its making for some very strange fuel maps so I am looking into TPS signal modification through the F/IC to alleviate the problem. I have a friend coming to help me watch gauges and push buttons this weekend to make the process go faster.
Other than that, things are working wonderfully. The sounds this thing makes are phenomenal! Im in love!
Gone but not forgotten:
) Its not purple dammit! Its
BOYSENBERRY!
New project
Daily When I go for a drive, I leave life behind. Friends, work, everything. Its just me, the car, and a twisty road. The exhilaration of being on the edge of catastrophe is something that I will never be able to give up.
WhiteDart is offline   Reply With Quote
Old April 20th, 2014, 08:16 PM   #55
WhiteDart
WhiteDart's Avatar
Update: My boost controller is a piece of crap. I get an inconsistent spike to 6psi which eventually bleeds back down to around 4psi by 5k rpms. I will be relocating the wastegate line closer to the manifold once I get a better boost controller.
Also had some flutter going on due to the undersize blow off valve I was using. Traded some parts to a friend for a Greddy RS which will do until I get a Tial Q BOV.
Pic:
Vid:
http://youtu.be/VCuHnI8bkJo
BOYSENBERRY!
New project
Old April 27th, 2014, 12:56 PM   #56
kresspy67
lol so true......
kresspy67 is offline   Reply With Quote
Old April 29th, 2014, 03:45 PM   #57
mx6gt04
Absolutely awesome.
One thing... I would highly recommend you putting a PCV back in. Not having any PCV at all will gunk up the inside of your engine faster than you would ever expect. You need to be constantly drawing air through that crankcase bud, if not... your engine will pay the price.
For my truck I found the brand new PCV valves never fully sealed (not uncommon that I cruise at 3-5 psi closed loop when towing for hours on end) so I ended up using.... a brake booster check valve off a Nissan pathfinder. Those will seal up to 20 psi or more.
Just saying....
94 MX3 V6 - 403 whp 412 ft lbs 15 psi pump gas. RIP
98 Ford Ranger 2wd: 5.0L twin turbo. 10 psi 408 rwhp 491 ft lbs 14 psi 478 rwhp 632 ft lbs
04 Volvo S60R 6 spd
mx6gt04 is offline   Reply With Quote
Old April 29th, 2014, 06:01 PM   #58
WhiteDart
WhiteDart's Avatar
I have a road draft tube coming off the back VC to a few inches above the ground so while the car is moving, it is creating a slight draw which pulles air in from the front VC and vents the crankcase. The PCV on the front VC is actually gutted so there is very little flow resistance. Going on 4 years and 40+k miles with this setup and the inside of the motor is still squeaky clean, just like the day I installed it.
In other news, I relocated the wastegate reference line to the elbow by the throttle body and installed my new Hallman boost controller. Boost is stable at 6psi. Car is tons of fun.
BOYSENBERRY!
New project
Old April 29th, 2014, 08:46 PM   #59
JoeeyCuz
Insane!
When your complete Id love to see a 0-60 vid
Twin Turbo KLZE *JIZ*
JoeeyCuz is offline   Reply With Quote
Old May 6th, 2014, 07:59 PM   #60
Onyxhammer
Originally Posted by KLZE Porsche View Post
Where did you get your Kevlar belt (assuming it is) from? There was a thread about them a while back and nobody ever posted a source. I would really like to find a Kevlar one!
I'm 99.99% rock auto sells them, I've put on two in the past I just can't remember exactly where it came from but I'm fairly certain where that came from.
Onyxhammer is offline   Reply With Quote
Old May 30th, 2014, 08:42 PM   #61
WhiteDart
WhiteDart's Avatar
So its official, the S injectors are no longer enough. Ive had the injectors go static a few times on some hard pulls. Not good. So the hunt is on for some 929's. Until then, boost is back down to around 4.5-5psi.
BOYSENBERRY!
New project
Old May 30th, 2014, 11:13 PM   #62
Ghostcloak
Subscribed!
One day, I'd like to do this to my MX6. I never cared for a single turbo setup and thought a TT setup would be impossible due to space constraints.
I look forward to seeing this completely worked out. Perhaps one day, if you are up for it, I'll make a trip to your part of the world and I can see this beast of yours in person.
Great work! Keep it up I look forward to seeing more.
2005 C6 Z51 460 glorious WHP
1997 Mazda MX6 LS Sold
1993 Ford Probe SE Sold
1985.5 Porsche 944 Sold
1993 Mazda MX3 RS Sold
Ghostcloak is offline   Reply With Quote
Old May 31st, 2014, 12:41 AM   #63
do you know what sort of whp your putting down and what fuel pressure you were running to max out the mill S's? (just out of curiosity).
Nitrous oxide. - 79' Yamaha QT50 'Yamahopper' 70cc, MLM pipe, VM18 carb, dual stage reeds etc.
Old May 31st, 2014, 01:36 PM   #64
WhiteDart
WhiteDart's Avatar
Not a clue on HP at the moment. Once I get some larger injectors and do a little tweaking, I will throw it on the dyno. Im running stock fuel pressure at 38psi @ idle/42wot. I know I can bump up the fuel pressure to act as faux larger injectors but I have killed three Walbro pumps, presumably from running 50+ psi. Im tired of dropping the tank. lol.
BOYSENBERRY!
New project
Old June 2nd, 2014, 07:52 PM   #65
short4stuff
On the Cutoff
short4stuff's Avatar
With the maf swap and the aem f/ic would you be able to run any other injectors other than the mazdas ? (s, 929) ex. nissans?
Just wondering where the aem f/ic ends at power wise before you would have to move to standalone.
94 PGT -T, Used to be quick
94 Black PGT, KLZE, spun bearing, Likely parts car for life
short4stuff is offline   Reply With Quote
Old June 2nd, 2014, 08:06 PM   #66
MonoxideChild
MonoxideChild's Avatar
There have been TT Probes even a decade ago. The most famous being the one from Michigan that rolled on video. Had the chance to see that car in Chicago is probably 2004 or so.
PaTricK
~ 92 PGT, 97 KL MTX 626, 05 Mazda6, 13 Mazda CX9, 09 Kia Sportage 4x4 v6 ~
MonoxideChild is offline   Reply With Quote
Old June 2nd, 2014, 08:53 PM   #67
WhiteDart
WhiteDart's Avatar
There have been people that used the F/IC and pushed over 700HP.
The F/IC 8 (the step above the 6) can control 2 additional injectors.
As long as the injectors are high impedance, I can run any injector I want. If I used the F/IC 8, I can control two additional injectors instead.
BOYSENBERRY!
New project
Old June 15th, 2014, 04:25 PM   #68
probe-gt
twin turbo probe WHAT!!!!!!!!!!!
probe-gt is offline   Reply With Quote
Old July 9th, 2014, 08:21 PM   #69
Dan [Sac]
Admiral General
Dan [Sac]'s Avatar
What's new, pussycat?
- KLZE, fender-flared, right hand drive, 2350 lb fully loaded sex machine. ||
||- SOLD
- 10.24 @ 139.9 mph ||545 whp @ 20 psi ||
- GONE
97 GTS - Rear Wheel Drive KLZE, 6-speed, 3.90 Torsen LSD, 2650 lb, daily driver! -
- GONE
90 Ghettocet KLiata - forever WIP
Dan [Sac] is offline   Reply With Quote
Old July 9th, 2014, 09:17 PM   #70
WhiteDart
WhiteDart's Avatar
Not a whole lot. Still drives like a dream (when I drive it once or twice a week. ). Still passively looking for injectors so I can bump the boost back up. Picked up the Autometer electric boost gauge I have always wanted a couple weeks ago so I have much better accuracy and peak recall. Im planning on a much more in depth overview of the car in the coming weeks.
BOYSENBERRY!
New project
Old July 10th, 2014, 12:46 AM   #71
Dan [Sac]
Admiral General
Dan [Sac]'s Avatar
What turbos did you end up using?
||- SOLD
- GONE
- GONE
Old July 10th, 2014, 06:45 AM   #72
Zepticon
I think ND28 got a set of 929 injectors for sale...
Mazda 626 GT - 2.5 V6 - KL31
Mazda RX-7 FD - EU spec
Zepticon is offline   Reply With Quote
Old November 5th, 2017, 05:26 PM   #73
Juans 93 MX3
Not Politically Aware Member
Any updates?
1993 MX3, KLZE & 5 Speed Swap
2008 Mazda 3 Sedan Sport
Juans 93 MX3 is offline   Reply With Quote
Old November 12th, 2017, 06:27 PM   #74
dprez
Nicely done, anything new?
dprez is offline   Reply With Quote
Old November 18th, 2017, 09:52 PM   #75
WhiteDart
WhiteDart's Avatar
Quite a few changes are underway over the past month. Increasing the size of all the charge piping, bigger Precision intercooler, MS3 + MS3X, and all new gauge setup, top feed injectors, A/C going back in... Just to name a few things. lol.
I have a lofty goal of 450whp in mind once I finally drop in the built motor sort out a trans solution.
https://photos.app.goo.gl/uEHNoq7MpqlJ23Gi2
https://photos.app.goo.gl/9yegQ4pNtzrC60703
BOYSENBERRY!
New project
Reality T.V. Steak Probe Lounge 20 May 27th, 2004 09:19 AM
The sad reality..... BloodRaven SCProbes 18 March 16th, 2004 05:36 AM
Reality Sucks silent hill 3 Probe Lounge 10 March 7th, 2004 04:22 PM
Is it reality yet???? Tical2000 Appearance Section 1 February 12th, 2002 09:25 PM
