93 PGT MTX, I couldn't find anything exactly like this mode of operation:
When cold starting, the car doesn't do fast idle.
TPS set, TB cleaned, IAC cleaned, hot idle 650-700rpms, timing 10 deg BTDC @ idle (per the instructions)
At hot idle, there is about a 50 rpm constant fluctuation in the idle. It just isn't smooth. It's barely detectable on the tach, but very detectable by the ear.
Once letting off the gas and putting in neutral, the engine speed goes down to ~1200, rests, goes to 800, rests, then goes to normal idle and stays there.
Any thoughts? The car is perfectly driveable as it is, but I'd like to get these issues out of the way.
The only code being thrown is a 16, EGR. Would that cause my problem? Removing the EGR does NOT sound like fun but I guess it has to be done.
