Old December 20th, 2017, 07:17 PM   #1
rod bender
No current to distributor.
Engine turns over, but won't start. There is no current going to the distributor. According to my Haynes manual there should be current where the red/black wire enters. I checked for continunity to a larger red black wire at the fuse box and get none. But I am not sure I even had the correct wires. I am stumped.
rod bender is offline   Reply With Quote
Old December 28th, 2017, 07:33 AM   #2
MSDKLZE
Turbo Junkie
MSDKLZE's Avatar
I cant believe it! the links are not broken!
The 3rd url link may help you tremendously.
Its from an old hack thread I made many moons ago. https://forums.probetalk.com/showthr...p?t=1701279431
Hope that helps!
DRIVE IT LIKE YOU BUILT IT!!
Old January 20th, 2018, 10:18 AM   #3
rod bender
It has a new distributor. I do not think the problem is the distributor, however. Current is not even getting to the distributor.
Old January 20th, 2018, 10:21 AM   #4
xrp861
Back probe said wire for continuity....
94 PGT
Old March 5th, 2018, 04:44 PM   #5
MSDKLZE
Turbo Junkie
MSDKLZE's Avatar
I don't completely know the workings of that circuit.... where does disty power input come from? ECU?
Something tells me that the spark system would probably have its own fuse or relay.
Old March 7th, 2018, 01:12 PM   #6
Whitefinish
Relay next to ecu
Mazda Mx3- Panther black, Kosei 18", custom hood, cleaned, new pakfeifer front, customized pakfeifer rear
KLZE highcompression, Pippercros Viper intake, kl31cams, MS1 v3, Aasco fly, CM st3 clutch, cai, ss headers, ground wirekit, srd bushings, msd window switches, nitrous
Whitefinish is offline   Reply With Quote
Old March 13th, 2018, 03:12 PM   #7
tcb2001
Relay?????
I'm having the same no start problem, went away when my mechanic swapped ECU's, makes me wonder if this caused relay to be disturbed and start working again. Is it able to be found,replaced?
Later,Doug
TCB in a Flash!
tcb2001 is offline   Reply With Quote
'96 Remanufactured Distributor and '94 rebuilt distributor for sale Gigi PT Member Sales 4 May 16th, 2007 08:34 AM
Distributor Bad? and Other Distributor Questions 89GT_then_96GT 2nd Gen (93-97) V6 2.5L 3 September 19th, 2004 01:52 PM
WTB: Distributor Ignition Module or Whole Distributor MikeC426 Wanted 0 June 18th, 2002 11:55 AM
Post Current WebCams of the City you live in(near) BigProbe The Photo and Video Gallery 19 May 26th, 2001 01:11 AM
hybrid t3/t04E on ebay for 400.oo (current bid)... jared r Forced Induction (Turbo/S.C.) 1 May 10th, 2001 07:56 PM
