Old January 9th, 2018, 12:13 PM   #1
Crank cradle swapping
Can we do it? Or is that like swapping cam caps?
Old January 9th, 2018, 08:41 PM   #2
You can -but then you will need a line bore. Yes it is like swapping cam caps around. The bores are only good with the parts that were bored originally. No two bores have the same alignment (unless by pure luck).
Old January 10th, 2018, 09:05 AM   #3
Fudge... much easier to drill out and re-tap the broken flange bolts then. Thank you!
Edit: Pure luck... I remember that movie, The bee sting scene by itself was hilarious.
Old March 5th, 2018, 04:51 PM   #4
MSDKLZE
Turbo Junkie
MSDKLZE's Avatar
Holy crap. I have multiple blocks taken apart and couldnt figure out why my gut was telling me not to randomly assemble an engine from them. Now I know why.
If you were to put two pieces together that were not of the same pair, is it possible to tell by feel or by sight if they would be compatible?
DRIVE IT LIKE YOU BUILT IT!!
Old March 6th, 2018, 06:10 PM   #5
Can you tell the different block parts go with each other by exterior corrosion/dirt level? I don't think I could mix up my 3 KLs, if they were all disassembled and in the same room.
Old March 6th, 2018, 07:18 PM   #6
mac1
Probe has-been
mac1's Avatar
Seen this happen with rear differential bearing caps getting mixed. Left from right and top/bottom. So I came to the rescue with bore guage and after measuring every direction I could. I figured it out.
2014 Factory Five 818s EJ255t
Old March 7th, 2018, 08:24 PM   #7
I would try to mate "fingerprints" to match uppers to lowers. Sometimes the oil leaves distinct prints between the pieces and on very few occasions -you can match up the stain "fingerprints".
Also -as previously mentioned -you might be able to match exteriors by the level of build-up, discolorations, corrosion etc. If you can narrow it down by a few -then for the last few as Mac has said -bolt em up, torque em and then mic em!
As some good advise -I ALWAYS put a couple of bolts into the pairs before storing them so that they never get mixed up.
?'s on main bearing/gridle(cradle) bolts. azichek 2nd Gen (93-97) V6 2.5L 4 November 5th, 2003 07:42 AM
Crank Crank Crank *whiirrrrrrrrrrrrr* FAST_91 Indy Probes 7 April 19th, 2003 04:22 PM
What sealant did Mazda use for the block to cradle mating surface? Dan [Sac] 2nd Gen (93-97) V6 2.5L Performance 14 November 8th, 2002 10:14 AM
crank crank crank thud crank crank iamdung 2nd Gen (93-97) V6 2.5L 29 May 1st, 2002 08:46 PM
WANTED,'93 and up RAD SUPPORT(CRADLE) and GT BUMPER WITH SUPPORT PL_RACER Wanted 0 December 1st, 2001 09:36 AM
