2.0L SC kit sale! Limited run, only 10 will be made!
Come on.. $800 to get most of what you need to boost an FS! That's CHEAP! everyone should go supercharged at this price! Not to mention the powerband is wider and more powerful than a conventional turbocharger.
Im very interested, in the whole 2k kit with everything. However I don't have the money to purchase it all at once. If I where to buy the kit in steps, would you rather I buy the $800 base first, so you can get parts made for other people, or would I be able to get the megasquirt, clutch, fuel pump and injectors first?
Purchasing the base first, imho would be best for a few reasons. This is a limited run, which may or may not get reproduced - and this way, you can get the 'unique' part of the entire project. MS, injectors, clutch, etc can always be obtained anytime. Also, it helps me to finish this quicker for each base kit purchased.
Thanks for the interest!
~Patrick
'00 Contour SVT - Stock and Reliable
'93 Probe GT - Currently Grounded.
Hey couple more questions.. Has anyone recivied their kit yet or do you need to fill 10 orders before shipping? From what I understand the probe se and mx6 rs have the same engine bay. correct? Just wondering if there would be any weird fitment issues with an mx6!
Actually once I get to 8, I can wrap up and ship out. I'm quite close to being there right now, with as much done as is.
I don't have messurements of a 2.0L MX-6, so I don't know if the radiator fans will or will not be an issue; the issue would only come with the intake side of the piping that has the air filter on it, this would be easy to modify though. With the probe there is a lot of clearance, so it's quite possible it will fit just fine. Other than that, it'll fit up perfectly.
Thanks again for your interest!
~Patrick
