Setting TPS, fans won't turn off!
  • Setting TPS, fans won't turn off!
    In the process of completing the MAF swap on my 94 ZE. Idles strong but extremely high. Go to do the fan method of setting the TPS as I've done several times in the past. However never on this car.
    Jumped the ground and ten pins, turned the ignition to the on position and the fans came right on. Loosened the screws on the TPS and slowly started moving it expecting the fans to kick off. They didn't. Full rotation in either direction and nothing. Even took the TPS completely off and the fans stayed running. Opened the throttle all the way by hand and still no luck. The fans just won't go off.
    Any ideas? Before the swap the car idled fine and the fans and coolant Gauges operated as normal. Please hit me with some ideas.
    Wild guess: is the throttle butterfly actually fully closed at idle? Or did the throttle cable get snagged somehow so it is stuck open? (The fan is supposed to come on when the throttle opens and go off with the throttle closed, with ten and ground jumped.)
      Someone may have messed with the idle screw on the throttle body. It is a very small stud and nut combination. Check that and let me know.
      1991 Ford Probe GT: Walbro 255HP,TKT T3/T04 .50 GN wheel, External Tial 38mm, .020 over, total seal rings, p&p, FMIC 28X7X3 core,440cc injectors
      1996 Ford Probe GT: KLZE ATX daily driver
        To clarify I meant the throttle stop screw. Not the idle screw. My fault. I have a ZE that came to me like that. Someone adjusted the throttle stop screw out to make the car idle faster.
          Mine came that way, sounded like a horrible vacuum leak
            your TPS might be bad.. i had one stay on all the time.. no matter where i moved it to .. swapped it out and then i was able to set it.. might want to try another one
            95 PGT Current project
            95 PSE swapped in 93 KL...Headers.... K&N cold Air.... Gutted Caged and ready for Dirt
            01 Seabring Convert 01 Neon Rims With Spacers..
            99 Olds Cutlas DD
              Thanks for the responses. The throttle stop screw is as tight as it can be however it's still barely touching the throttle linkage. I was informed it shouldn't be touching at all.
              I'm going to put a different TPS on there. Are they interchangeable throughout all years? I have one laying around but have no idea what it came out of?
                yea they all are the same as far as i know
                99 Olds Cutlas DD
                  The only one that I know is different on a KL is the 98-02 626 KLG4 TPS, which is a 3 pin TPS so you'd notice a difference.
                    Update:
                    Switched out the TPS and everything worked perfectly. MAF swap complete and she's idling smooth at 700-750. Didn't get a chance to take her for a spin but based on the throttle response alone At idle I'm expecting to be very pleased. Thanks for the help.
                      DE, ZE, G4, hybrid? Glad to hear it's fixed.
                        It's a ZE
                          Originally posted by panic37 View Post
                          Update:
                          i was pretty sure your tps was the issue... glad it is working for ya
                          99 Olds Cutlas DD
                            The freeway is where I notice the MAF swap the most. 3rd gear 55-60mph or so on up.
