Ok, it died on the highway got 75 set on Cruise control, after running GREAT for 2 days. Timing belt shreded, so after replacing belt and tensioner pully, properly aligning cams and crank to TDC, the engine still wont crank over. It does crank, but will not turn on. Could it be the ECU, MAF, or any other guesses????? We did get it to run for a sec. with the throttle wide open and someone pushing in the cone on the MAF, but once it started, it sounded horriable, then died again. This engine is a non-interference engine.
1994 MX6-manual (Just some engine specs-KLZE-10.2:1 wiesco pistons, millenia rods, titanium retainers, dual valve springs-frerra-probinator chip on de ecu)
Please any help or previous experience would releave a ton of stress on me right now, it is my DD and i need it asap! Thanks Guys
