97 detailed
  • #61
    This is a picture from last year, minor differences.
    97 pgt, manual swap, jdm lsd trans, cm stage 2 clutch, mx3 flywheel, cai
    2001 626
    • #62
      I like the fan shroud and I like the reflector
      I've debated doing that to my reflector multiple times but just decided to leave it as is.
      1996 Probe GT - Bought April 2010, Boosted August 2014
      Fast FC04 18x9, Black Leather, King6, ADDCO, AWR, Yonaka, Quad J30s, AVC Pipes, Tial WG, Greddy BOV, Aeromotive AFPR, MS1v3
      1993 Probe GT - 110k, auto, parts car
      2011 Impreza Limited Hatchback - Daily, Lowered, WRX Wheels & Wing
      • #63
        Car looks sharp, the chrome swirlies really set it off.
        • #64
          Thanks guys!, I need new tires so I've been debating buying rims/tires or just new tires for the swirlies and after hydroplaning and almost wrecking it I think I'll just get new tires while I search for rims.
          I fount a guy selling parts cheap and I bought that refelctor as a spare, and decided to paint it. It is cracked on the top side that is hidden by the trunk.
          2001 626
          • #65
            I started the manual swap tonight, I almost have the new pedals installed
            2001 626
            • #66
              The pedals were my least favorite part of the swap. Beautiful and clean car!
              • #67
                Thanks!, I try to keep it clean and take care of her. but it's hard to find the time these days. I figured the pedals were going to be a pita to install, I'm waiting on a few other parts but that will happen after this weekend then I'll tackle the trans
                2001 626
                • #68
                  You TRY to keep it clean? LOL. I would say from looking at the pics, you did WAY better then try, that car looks amazing
                  • #69
                    Thanks man!^, I've been slowly tearing this car apart each night after work, today i removed the starter. it was a pita. The passenger side axle nut wouldn't come off so I removed the hole hub, I will bring it to work to use a better impact and maybe torches. I'm hoping to pull the trans this weekend and install the clutch line, clutch master and the new brake master cylinder.
                    2001 626
                    • #70
                      Bravo for the determination
                      • #71
                        Thanks Dan, I find it difficult to do the manual swap so I couldn't imagine what it would have been like to create the kl-powered rwd probe. It's looking beautiful with the choice of wheels btw.
                        2001 626
                        • #72
                          I have a question, I removed the flexplate and the metal adapter behind it, bolted my flywheel/clutch to the crank then I was able to slide the trans on, However it won't slide in the whole way. It stays out about a quarter inch on the bottom. any ideas as to what is holding it back?
                          edit, I didn't aling the clutch disc properly. problem solved.
                          2001 626
                          • #73
                            new edition to my pile of parts
                            2001 626
                            • #74
                              C'mon. Stop teasing! Pics on the car !
                              • #75
                                I'll have to snap some of them on it this weekend, lol. I work 12 hour days between school and work and I have to reinstall the front hubs before I can put these bad boys on. but I'm hoping to make some real progress this sunday.
                                2001 626
