As many of you know I can regrind your cams (kl-03) to a cam profile that is very streetable. The engine will idle at stock level, without any hesitation. I've sold two set already and I have one more coming my way. The specs of this grind is 0.353" lift, and 208.6 deg @ 0.050". This grind I can offer it at $375US + shipping.
Now with the Colt cams. I've worked very closely with Geoff Bardal (owner of Colt cams) in making a cam profile for our cars. The profile in question is the superstreet grind. This grind is very similar to the other one, but slightly more aggressive. I'm stressing the word SLIGHTLY. It has a lift of 0.355", and 210 deg @ 0.050". This cam also idles at stock level but with a bit of burble. I can offer this grind for $450US + shipping.
Both grind will produce the same power give or take 1whp.
I also have another grind for owners of ZE. This grind is a dual cam lobe pattern. Meaning that the exhaust and intake cam profiles are different. The intake is 0.363" lift, and 208 deg @ 0.050", whereas the exhaust is the same as the first profile above offered by me (0.353" lift, 208.6 deg @ 0.050"). The reason that I'm offering this is because this is what I have on my ZE. This grind cannot be used on 03 heads due to the smaller intake HLA found in comparison to the ZE intake HLA. This grind is offered for special order.
I don't own a shop but I worked with a cam grinding shop in my area to come up with the grind I'm offering.
As for the Colt cams I'm taking over all the mess that happened with Black Sheep Racing (BSR). DO NOT SEND MONEY TO BSR if you want Colt cams, you can visit the Performance section and look at sticky " For those who ordered Colt Cams" to get the whole story.
If you're interested let me know which one you'll take.
