Old February 7th, 2018, 02:28 PM   #26
It was done about 5 years ago now, i told them to shave the head if it wasnt flat and its my fault i didnt ask for a spec sheet.
Nitrous Oxide - 79' Yamaha QT50 'Yamahopper' 70cc, MLM pipe, VM18 carb, dual stage reeds etc.
Old February 12th, 2018, 03:17 AM   #27
I just wanted to update the thread, i have a new pulley and am in the process of putting it all back together (leaking water pump has been replaced) so this weekend i should be able to tell if it has made a difference or not.
Retarding Cam Timing RRL777 2nd Gen (93-97) V6 2.5L Performance 5 July 11th, 2006 03:45 PM
Anyone ever tried retarding cam timing? cyborgzero 2nd Gen (93-97) V6 2.5L Performance 34 April 9th, 2006 12:06 AM
Retarding Timing while spraying??? Tweaked N2O Technical 23 March 19th, 2002 07:19 PM
Retarding timing 4 degrees? Twenty36_1 N2O Technical 21 February 4th, 2002 08:18 AM
Advance timing by retarding timing?! dj petey 2nd Gen (93-97) V6 2.5L Performance 3 October 4th, 2001 06:18 PM
