Old February 4th, 2018, 01:31 PM   #1
how-high
pop up lights not coming up and down
hi
normally they work fine
but sometimes they not come up othertimes they not come down
if this happends I need to try couple to many times before moving
its allways both sides same time, so where do I start?
how-high is offline   Reply With Quote
Old February 4th, 2018, 04:36 PM   #2
Originally Posted by how-high View Post
hi
It is the headlight motors. Brushes are worn out. You can either rebuild them as a few have done -or find replacement motors.
Old February 4th, 2018, 04:52 PM   #3
Level 9
Check the retra relay for any corrosion. If it is both sides at the same time it sounds like more of a possible electrical issue. I'm not sure if there is anything in the interior fuse box related to them but I have had some corrosion on a few fuses in the past. I know the wiring on the 93 is a little different for the headlights so I must ask what year is yours?
Old February 4th, 2018, 04:54 PM   #4
how-high
its 1993, whats or where is the retra relay?
Old February 4th, 2018, 05:17 PM   #5
Yes -I missed reading where you said that both are doing this at the same time. So I am with the relay answer above.
Old February 4th, 2018, 06:57 PM   #6
They share a ground wire to the chassis I think
Old February 5th, 2018, 05:44 AM   #7
how-high
where I can find the retra relay? and this ground?
Old February 5th, 2018, 07:47 AM   #8
Level 9
The retra relay is in the fuse box under the hood, the ground locations need checked a well and those I am unsure of the location.
Old February 5th, 2018, 11:30 AM   #9
how-high
under the dash behind the handle to open the hood I see something marked relay retra
you mean this one? or is there another one under the hood?
https://i.imgur.com/yzdyfnG.jpg
Old February 5th, 2018, 11:57 AM   #10
how-high
or you guys mean this headlamp relay ka30
https://i.imgur.com/eWkc1RQ.jpg
Old February 5th, 2018, 02:24 PM   #11
Level 9
The ka30. Some covers say retra in that same spot. Pull it out and make sure the contacts are clean. Also the 93 has some extra wiring and is ran a little different since that year you are able to put the lights up without turning them on. I sold my 93 about 15 years ago so can't go look at it. It's been a bit since I have had my bumper off but I think I recall some grounds tied together under the headlight going to the chassis but I could be mistaken. Check the relayband try to back track the headlight wiring looking for their ground.
pop pop ziggyturbo89 Midwest Fords & Mazdas 0 July 1st, 2010 09:58 AM
one pop accelerate, one pop brakes? Rocko 2nd Gen (93-97) V6 2.5L 9 March 29th, 2004 03:39 PM
HEadlights go up and down, up and down, up and down... shibby2002 1st Gen (89-92) All 14 May 15th, 2002 10:59 AM
Pop-Up lights, no...wait...Pop-DOWN lights?! REDPGT Probe Lounge 10 August 23rd, 2001 06:23 PM
pop up lights won't pop DOWN gettingaprobe 2nd Gen (93-97) V6 2.5L 1 July 15th, 2001 11:55 PM
