Old February 6th, 2018, 06:10 PM   #1
how-high
amplifier fuse melting
why is my amplifier fuse melting?
https://i.imgur.com/7jhuUlq.jpg
how-high is offline   Reply With Quote
Old February 6th, 2018, 09:38 PM   #2
Is the amp rated higher than the wiring is? That's most likely the cause, maybe more resistance and heat from a crusty old wire. Is your car a 94 in Portofino blue?
Old February 7th, 2018, 05:49 AM   #3
Level 9
I buddy of mine his car some years back had a similar problem where his power wire started melting down, it ended up being a spot in the wiring where it was ran rubbed through and was grounding. Although it was a pretty sudden problem and affected a lot of the wire, not just the fuse area. As blue stated above that will do it too for sure. Few things to check.
Old February 8th, 2018, 06:19 AM   #4
how-high
93 Royal Blue
I found part of the end I connected to a smaller wire, it had melted a part together with the ground wire
guess it was grounding there
Old February 8th, 2018, 02:29 PM   #5
stoker100
stoker100's Avatar
as mentioned above, the fuse is too large for the wiring and im also 99% sure its a poor connection to melt there, the screw cap probably came loose and caused an intermittent connection which arc'd causing the heat to make the plastic to melt, if you replace it with a new one with a lower rating it should be fine.
A melting pot of ?'s!!! azichek Racing/Suspension 7 February 12th, 2004 09:07 AM
The Snow Is Melting!!!! Friday128 Probe Lounge 0 December 31st, 2003 09:57 AM
melting plugs in my friends z24 91PGT N2O Technical 11 July 8th, 2002 08:17 PM
Melting Carpet Probe_#1 2nd Gen (93-97) I4 2.0L 5 April 17th, 2001 08:03 AM
Plastic melting smell....HELP! BaD|BoY 2nd Gen (93-97) V6 2.5L 1 April 2nd, 2001 10:05 AM
