Old February 11th, 2018, 12:05 PM   #1
Level 9
95 motor into 96 questions
Considering purchasing a 96 PGT atx and swapping my 95 mtx motor and trans into it. Questions are:
Is there any connections on the motor that are different other than maybe the distributor?
Also could the ecu from the 96 be swapped with the one from the 95? If so how is the wiring affected at the disty... Or if it is just a no go since I have my MS on my 95 how nice does MS play with OBD ll? Just wondering if anyone else has gone down this road before.
This other car has a cooked motor and I do not want anything to do with the atx but has a clean body. Just exploring my options, thinking it won't be too bad just to swap everything around. The atx-mtx swap doesn't bother me.
I need a master cylinder anyways so I'll be purchasing a new master, clutch master, neutral safety switch since mine is jacked, along with a booster if I go this route.
Level 9 is online now   Reply With Quote
Old February 12th, 2018, 11:59 PM   #2
xrp861
Strip both cars. Remove the full 96 harness carefully...from front to rear no bs it's a pita but worth it trust me.if you're not keeping the 95 harness cut it out and toss it. In my 94 I kept the sunroof wiring as per my 96 didn't have one...and it worked. But it's pretty easy. Pm me if you want me number I'm in mi as well.
94 PGT
Old February 14th, 2018, 11:17 AM   #3
Level 9
Will the motor from the 95 drop into the 96 and plug and play?
I would consider pulling the harness and ecu if needed to remain to be able to use megasqurt. On the flip side if the motor will just simply install with a swap of a couple sensors for this year I would prefer to go that route so I can go through the car thoroughly next winter.
Will keep that in mind too that you are in MI as well. I'll shoot you a pm if I end up picking this car up. Have a few options I'm still exploring. Decisions decisions, just these things are getting harder to come across now.
Old February 14th, 2018, 05:22 PM   #4
Brizzy
The motors themselves are the same, the engine harness is a bit different.
Just change the engine harness during the swap.
1994 Project PGT
M62 In Progress...
Brizzy is online now   Reply With Quote
Old February 14th, 2018, 08:14 PM   #5
Isn't it just more O2 sensors on the 96? Otherwise should be the same? Where's that thread with the year - year differences?
Old February 14th, 2018, 08:59 PM   #6
xrp861
No and it's not that simple ever with any dash harness unless it's year for year as far as I've seen.
---------- Post added at 10:59 PM ---------- Previous post was at 10:56 PM ----------
All the wiring needs to be changed trust me. I went 94 to 96. Motor wise it'll be easy but I'd swap all the wiring for the simple fact of its for a mtx car and eff all the atx bs.
94 PGT
Old February 16th, 2018, 04:18 PM   #7
richtq
just use everthing from the 96 and swap everything to the other engine that you need like exhaust manifolds and what not. If the coolant sensors are different just wap it all over to what the 96 needs and keep it simple.
No more leaks and running great 270whp 259 torque
8psi
richtq is offline   Reply With Quote
Old February 17th, 2018, 08:43 AM   #8
xrp861
Removing a pos obd1 system and re wiring the csr to obd2 which is set up for mtx is the best option. There will be a birds nest in the bay above the trans and many stupid issues otherwise I'm sure. Again if you want any pointers pm me for my number.
94 PGT
Old February 17th, 2018, 09:02 AM   #9
Brizzy
I would hardly say obd 2 is good.
1994 Project PGT
M62 In Progress...
Old February 18th, 2018, 12:41 PM   #10
xrp861
I've had not one issue with my 96 loom and maf swap. It's not the system that sucks it's lack of knowledge on how to back probe and troubleshoot electrical. The obd2 system on the 96 up probes is not any bit less or more fussy then anything made now. I've successfully wired up 2 obd1 cars to run maf swap piggy back style as well on the same ecu I run that supposedly has no speedo function yet both worked no issues. So I have no idea what you're even remotely talking about.
94 PGT
Old February 18th, 2018, 04:14 PM   #11
Has anyone ever posted dynos sheets of a before and after MAF conversion to show solid proof that there are gains and a reason for doing it?
If there is nothing in writing or shown in solid evidence -I can't see the point of going to the trouble. OBDI is good because you can program a chip for it -where as -you can't for OBDII.
So my vote will always be for OBDI -unless someone can show me something that will outweigh being able to tune my computer for best performance without having to go to MS.
Old February 19th, 2018, 12:22 AM   #12
xrp861
It's in the thread for it sir
94 PGT
Old February 19th, 2018, 10:44 AM   #13
SuperSquid
It's all J-dogg's fault
SuperSquid's Avatar
If I had to do an ATX>MTX conversion again...I would skip everything and just install an MS unit. We did one a few years ago and you have to pull 3 harnesses to do it with the ECU from the donor car. Also, since you are using an OBDI car as a donor....and an OBDII car as recipient....you'll run into problems if you have any kind of inspection where they require OBDII on a 96 model year car.
Old February 19th, 2018, 08:59 PM   #14
xrp861
Reasons to use the whole obd2 car wiring harness...also here in mi we have no inspections.
94 PGT
Old February 19th, 2018, 10:16 PM   #15
You can always use newer stuff from the same model, legally. Newer engine, controls, etc., as long as it's all installed properly and working. Upgrading to an engine that wasn't an option is where things get gray. Can't get better than "no inspections" though.
Swapping '94 GT motor into 93 ATX - questions Savage Messiah 2nd Gen (93-97) V6 2.5L 2 October 27th, 2004 04:27 PM
Can't get into 1st gear without going into 2nd gear first. ELPGT95 2nd Gen (93-97) V6 2.5L 13 August 15th, 2003 02:33 PM
Looking into a new motor but have a few questions? sxxdnne 1st Gen (89-92) Performance 1 June 25th, 2002 11:15 AM
Equal length pipes / 2 into 1 / 2 into turbo / sizes??? GET_PROBED Forced Induction (Turbo/S.C.) 5 April 24th, 2002 01:15 PM
