Go Back   ProbeTalk.com Forums > Vendor Support and Contact > Former Vendors > Grounded Conceptz
Grounded Conceptz For all your body kit needs, visit Grounded Conceptz
Old October 19th, 2009, 09:20 AM   #1
Jamie C
Jamie C's Avatar
KSport Coilovers for 88-92 Ford Probe
Thats right Grounded Conceptz now has access to a full coilover suspension for first gen probes. The Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car.
Key features are:
-36 levels of adjustable dampening
-Made from high quality 6061 aluminum with T6 for increased hardness
-Compression/Rebound adjustable
-Adjustable spring perch for height adjustment
-Adjustable body allowing maximum suspension travel
-Pillowball top mount with adjustable camber (not available for some models)
-Monotube high pressure design reduces oil leakage
-Electroplated body for protection from corrosion and rust
-One year limited warranty
MSRP on these coilovers are $1350 but we have a deal so good that the manufacturer will not let us list the price on the internet. PM for up to date pricing and shipping rates.
And FYI...the sooner you order the cheaper the kit is..
If you have any other questions please visit http://www.ksportusa.com/asp/coilove...roduct_id=cd01
or PM me.
Jamie C is offline
Old October 22nd, 2009, 06:22 AM   #2
BoostedMan
Cool,
Question, What's this mean (Pillowball top mount with adjustable camber (not available for some models) by certain models?
Do these come with adjustable camber plates?
BoostedMan is offline
Old October 23rd, 2009, 11:24 AM   #3
Jamie C
Jamie C's Avatar
Hey there
In the simplest to explain this, these coilovers look like your stock suspension but at the top of the coilover, where it connects to the body, there is a pillowball mount, which allows you to adjust the camber as there are notches for all settings.
The front coilovers are pillowball top mount and the rears are aluminum mount.
The pillowball is adjustable, it has notches so you can line both side's up.
However, Ksport does recommend that you get an alignment to have them installed correctly.
Thanks for the question
Stefan.M
GC
Jamie C is offline
[IMG] code is On
