So, was working with my son this weekend to get his GT finished up. We replaced his rear calipers and adjusted them. While doing so I sprayed silicon lube in the parking brake cables cause they felt like they kept getting stuck/hung up. Had my son pull the ebrake a few times while I would pull the cable back out after release.
After this, put it all back together, pulled the cable. It was really tight then nothing. Felt like at least 1 cable broke. Maybe at the handle. Is this a correct assumption? Should the cables move easily?
So, I am planning on just replacing everything cable wise. My main question is, what is the best way to do this? Seems like I will need to remove heat shields. Anything else? Anyone have any pics or links discussing the process?
