I'm in
Stainless Door Sills Bulk Buy!!!
This topic is closed.
I'm def in this time around1996 PGT atx...for now, Intake, exhaust, yonaka coilovers http://forums.probetalk.com/showthread.php?t=1701306455...wrecked, put back to stock, Sold
1994 PGT MTX...http://forums.probetalk.com/showthread.php?t=1701309068
I may have to get in on round 2 also. Do you have pics of the underside? Do they only mount where the two screws are? What about moisture/water getting underneith them?95 GT Chameleon Beauty
http://i473.photobucket.com/albums/r...ps15cc5293.jpg
"Without Risk There Is No Reward"
They are stainless steel. Moisture wont affect them
And yes, they only mount at the 2 screws (bolts threaded into clips in the factory locations
I will have to talk to damon/stacey about another bulk buyLast edited by polarexpress17; May 2, 2013, 05:02 PM.95 mx6 with a 4 lug swap
Built, Not Bought.
No, my username is Not from that stupid movie.
Originally posted by polarexpress17 View PostThey are stainless steel. Moisture wont affect them
I will have to talk to damon/stacey about another bulk buy95 GT Chameleon Beauty
ah i understand your question now, if you are concerned you can buy plastic clips with flat heads to put in the holes that aren't used to help seal them, however the factory plastic door sills don't actually "seal" those holes either, they are used for guides and clips, no sealing properties whatsoever :-)95 mx6 with a 4 lug swap
Built, Not Bought.
