hey guys ,, have a 95 2.0 litre which I love to drive.. Car just died.. no spark ,, dont know where to start? any suggestions?
2.0 no spark
check for spark by removing one spark plug then re-attach the ignition wire and ground the threaded portion of the plug to a good engine ground then have a friend crank it over while you watch for spark..if no spark check for 12 volts at the power wire at the distributor when cranking (i think its black/red or black/pink)..if you get 12 volts then the ignition control module is bad...95ATX its inside the disty..MTX might be external
