my 89 has been sitting a few years and I've just replaced the alternator but worried to just start it up without knowing the quality of the gas. what's the best way to check if the gas is healthy still or not? or should I just turn the key and see if she runs? thanks
how can I check if fuel is good/bad
Bad fuel can cause her not to run. It won't hurt to try to start her up in my opinion. How much fuel is in the tank? At parts stores they do sell stabilizer for fuel. You could always add that and then add fresh gas.
Bad gas can also clog the fuel filter. If you can not get her running try changing the fuel filter. If she starts I would look into changing the fuel filter after you run a couple tanks through her too.
