After a year or so here is my contribution to PT. After doing some searching I couldn’t find anything specific for connecting an A/F gauge to the ECU inside the cabin. The advantage to doing it this way is you don’t have to run any long wires through the firewall down to an 02 sensor. Hopefully I got it right. This was done on a Mazda so the dash piece is probably different but the ECU and wire connections are identical. I prefer a lower profile car so I decided against a gauge pod. The Mazda has a place under the stereo perfect for 2" gauges. I couldn’t find any black plastic locally so frustrated I went to Pep Boys to look for ideas. I ended up buying a truck mud flap (dont laugh). I am glad I didn’t use plastic because the mud flap which is just under a 1/4 inch think is soft enough to bend but hard enough to stay rigid once in place.
here is a pic of the cutting area (my carport)
http://ns1.vs186.server4me.comb4tn/m...ll/cutting.jpg
Some how while trying to fix the links I managed to delete almost the entire post! I have no idea how. But the most important pic is below. if you have any question I will try to answer the best I can.
http://ns1.vs186.server4me.com/b4tn/...all/splice.jpg[/img]
