Go Back   ProbeTalk.com Forums > Probe Owners Clubs > Southern California Probe Owners Club
Southern California Probe Owners Club Serving Sunny Southern California
Old August 28th, 2015, 08:48 AM   #1
Eric351M
Acquired a FREE KL
Okay, so my Probe has been out of commission for a good while now due to serious overheating. The gaskets might have been the starting point but I think the heads were done for.
Anyways, after my car broke down my sisters boyfriend bought a curve neck ZE to install into his SE. Long story short, he lost interest in it and decided to give me the engine.
So what this means is that i'm going to need some helpful SoCal hands to get my probe back on the streets. I was having serious Probe withdraws and it didn't help that I was driving a Prius
1994 Coral Mist Metallic PGT
Eric351M is offline   Reply With Quote
Old August 29th, 2015, 12:29 AM   #2
supercharged3.0
Are you buying the beer ( I like IPA)?
supercharged3.0 is offline   Reply With Quote
Old August 29th, 2015, 05:23 AM   #3
Eric351M
I'll buy the beer and carne asada.
Old August 31st, 2015, 07:50 AM   #4
91GtFe
Sadly is not a high compression motor and doesn't have Ze cams. The heads are the best part of it. Good luck with it, too bad I'm not in so cal anymore.
it's not the fall that hurts, its the sudden stop at the bottom
91GtFe is offline   Reply With Quote
Old September 1st, 2015, 01:06 PM   #5
dmark101
Obfuscatory & Abstruse Nomenclature
dmark101's Avatar
who are you?
eric, i'd be down to help. just need to know when and where.
dmark101 is offline   Reply With Quote
Old September 3rd, 2015, 06:36 PM   #6
supercharged3.0
do you have a cherry picker?
---------- Post added at 04:36 PM ---------- Previous post was at 04:35 PM ----------
Put some pics what you got there
Old September 3rd, 2015, 11:22 PM   #7
yellowrob
Cherry picker?? Since when is a chain and tree not good enough.
Some people are living life and some people are just living.
yellowrob is offline   Reply With Quote
Old September 4th, 2015, 11:37 AM   #8
dmark101
dmark101's Avatar
he may not have a tree handy where he lives. plus, this isn't the first engine swap he's done. i'm pretty sure he's got a lift. if not, my brother does and he's not too far away
Old September 4th, 2015, 12:08 PM   #9
yellowrob
Oh yea that's right I forgot you guy's were ablaze over there. Any of you guy's near the fires?
Old September 7th, 2015, 07:46 AM   #10
Eric351M
I'm actually going to get a cherry picker soon here and the probe is going to be in Pomona. I bought a house down here.
Old September 7th, 2015, 10:26 AM   #11
91GtFe
Originally Posted by dmark101 View Post
who are you?
Why does it matter who I am.
Old September 7th, 2015, 01:03 PM   #12
yellowrob
He asked because it seems like you've seen the motor he got and inspected it.
Old October 13th, 2015, 07:11 PM   #13
Eric351M
So I was finally able to get the engine over to my house:
http://i34.photobucket.com/albums/d1...913_160315.jpg
http://i34.photobucket.com/albums/d1...010_110645.jpg
Now to do some maintenance and cleaning it up. Lets see if I don't mess up the timing.
Old October 14th, 2015, 12:03 PM   #14
dmark101
dmark101's Avatar
because i asked and also because you appeared to have detailed knowledge of this specific engine, but the most important reason is because i asked.
eric. with that curved neck manifold, i would definitely check the casting numbers on both the heads AND the cams to ensure that this is a bona fide KLZE.
i've noticed that the valve cover has the raised lettering on the top and bottom sections. i want to say this came from a millenia with the "hybrid" motor [DE block - ZE heads w/o ZE cams]. both the IM and VC are near dead giveaways, but you'd have to check the castings to be sure.
good to see your brother helping you out.
32nd ANNUAL FABULOUS FORDS FOREVER - APRIL 30, 2017
Every Probe owner in CA is encouraged to attend! - Plan for it NOW!
Old October 14th, 2015, 03:16 PM   #15
j-dogg
/p/hotoPOC
j-dogg's Avatar
Location: pwning the crap out of supersquid in Unreal Tournament
I'm going to go out on a limb and say it's a millenia motor, which as long as it's clean who cares what it looks like, free motor.
PhôtôPOC(tm)
MM9 MMX FF FF2 FF3 FF4 FF5
95' base 297k of DD sex on factory-sealed motor and climbing, Eibach pro kit, chrome swirls, 626 swaybar, front and rear STB's, Frankenprobe's Brembro rotors, ice-cold AC
93' PGT 157k stocker current boost project, JVC headunit, Alpine audio, trans saver, STBs
2016 Freightliner Cascadia Evolution 505hp 1800ft.lb., the money maker
j-dogg is offline   Reply With Quote
Old October 15th, 2015, 06:08 AM   #16
Eric351M
Okay, so it's not a ZE, it has KL-101 and KL-1A1. As long as it works and I can drive my car again, I'll be a happy camper. Plus it gives me practice to installing the real thing later.
Old October 15th, 2015, 09:47 AM   #17
KLZEEscortGT
You can still have the kl01 heads and cams with the curve neck, but it's very possible to have the high compression pistons. It's been said on here before, but by the stamping number on the throttle body it should tell you if it has them or not. Sorry I can't remember the correct number, but I'm sure someone else who knows will chime in.
The curve neck ZE with kl01 heads and cams are pretty common motors but any that I've seen have the high compression pistons in them. I have one currently in my car, one on an engine stand and the original one that was in my car. But are usually pretty clean.
---------- Post added at 07:47 AM ---------- Previous post was at 07:45 AM ----------
Not true at all. Trying doing some research first before you post something.
1995 Escort GT lowered, KLZE, CAI, long tubes, 2.5 inch exhaust, Fidanza fw, mx3 trans, and on ZEX
1996 Escort LX bagged, mx3 leather buckets, gt bumpers and skirts, 2.0l zetec swapped, cai, borla muffler, 3 yellow tops, Hornblasters train horn kit and a MASSIVE sound system
KLZEEscortGT is offline   Reply With Quote
Old November 13th, 2015, 12:30 PM   #18
dmark101
dmark101's Avatar
eric, did you get this motor installed?
Old November 15th, 2015, 07:40 PM   #19
Eric351M
To tell you the truth, I got a little scared to even start on it. I started taking it apart to clean it up and do some maintenance on it. I think i'm going to do the timing belt as one side of the belt is a little chipped. I just hope I can do it as I haven't done it before.
Then there is still the issue of bringing the car to me to do the swap.
---------- Post added at 06:40 PM ---------- Previous post was at 06:38 PM ----------
I noticed that the rear head was a lot cleaner than the front head.
http://i34.photobucket.com/albums/d1...114_141212.jpg
Old November 17th, 2015, 10:45 AM   #20
dmark101
dmark101's Avatar
the head issue is kind of normal. probably VCG or maybe the grommet on the PCV isn't sealing properly.
where's the car now? heh, i should take my probe up there so i can swap out my rack without any issues from my overlord. just waiting on getting it from napa.
Old November 17th, 2015, 12:38 PM   #21
BlackProbe
yes you can have a oval port engine with 10:1 compression..Ive had one before ..Tell you the truth,drop some ze cams in there,an you wont be able to tell the difference..
93 Probe gt- ,15.37 1/4 mile at mph 85 ** 5/24/03 14.71 SOLD
1994 gt -klze,I/h/e/fly/ignition/kl31 ecu,colt210/210 cams Rip 2/13/08(blackice)
92 mx3gs,ze swap from my probe 15.0@96mph :-( 175hp&155tq
BlackProbe is offline   Reply With Quote
Old November 18th, 2015, 05:09 AM   #22
Eric351M
The car is in hesperia and I bought a house in Pomona so I have to bring it down here. The rack is something I have to replace as well but it will be a lot easier to do with the engine out.
Old November 18th, 2015, 02:16 PM   #23
dmark101
dmark101's Avatar
that was my plan too, plus i wanted to swap out the heads on my ZE with the heads i took off of my mx-6's ZE before i got rid of the car.
for now, i'll do the easiest thing: the rack. i still have to get the heads cleaned up.
Old November 21st, 2015, 07:38 PM   #24
Eric351M
I got the engine all cleaned up and I changed the water pump and timing belt. Was easier than I thought.
http://i34.photobucket.com/albums/d1...121_125555.jpg
http://i34.photobucket.com/albums/d1...121_124837.jpg
Old November 21st, 2015, 09:32 PM   #25
yellowrob
Cleaned up nice, good job bro.
Just Acquired a Free 94 4X4 Blazer, Woot! Tommy Probe Lounge 29 December 31st, 2009 02:05 PM
My newly acquired '95 GT spada Probe Pic & Video Post 9 September 14th, 2009 02:53 PM
Recently Acquired shockthaworld2 Appearance Section 6 January 25th, 2007 10:24 AM
96 Ford Service CD Acquired 190km/h 2nd Gen (93-97) V6 2.5L 7 January 1st, 2002 10:37 AM
acquired experience? eunosads Probe Lounge 7 October 24th, 2001 09:53 AM
