Go Back   ProbeTalk.com Forums > Probe Owners Clubs > Southern California Probe Owners Club
Southern California Probe Owners Club Serving Sunny Southern California
Old November 23rd, 2015, 01:57 AM   #26
dmark101
Obfuscatory & Abstruse Nomenclature
dmark101's Avatar
yeah, the water pump and timing belt are pretty easy to do, especially with the engine out of the car.
btw, i should be getting my rack in on tuesday. hopefully i can get it done before the end of the year.
dmark101 is offline   Reply With Quote
Old December 4th, 2015, 08:41 AM   #27
Eric351M
Okay, so I just noticed that the timing belt kit I got was the different size water pump shaft. My question is do I need to get another water pump or can I just get the correct sized pulley?
Thanks for any input
1994 Coral Mist Metallic PGT
Eric351M is offline   Reply With Quote
Old December 4th, 2015, 10:25 AM   #28
DougieFBabY
Looks real nice, good f.... Work man.
U don't want a full ze engine.anyway, their heads are trash and known for.dropping.valves!!!!
Besides zes are.overrated, cams are all u need from them
I had a de wit ze cams and my boy had a real ze and we raced.our probes, same clutch setup, and he pulled.by seriously the width of a finger, LOL, if that and I missed a shift, clutch was still new, if I.had nailed that shift I would have pulled
DougieFBabY is offline   Reply With Quote
Old December 4th, 2015, 01:53 PM   #29
dmark101
dmark101's Avatar
you can just get the right pulley. junk yard should have them if you can find a probe/mx-6/626 in there.
i'm curious. what size shaft did the pump have eric? 32mm? i wound up having to replace my pump not too long before i shut the car down. place gave me the 32mm shaft. i was lucky though, because my mx-6 had that size and i had kept the pulley.
i still have my 16mm though. the new rack i bought actually came with the rubber bushing for the mounting clamp. sweet.
Old December 5th, 2015, 06:32 PM   #30
Eric351M
The engine had the 32mm and the timing kit had the 16mm.
I went to one junk yard a found nothing. I think it's going to be harder to find parts at the junk yard for probes.
Old December 6th, 2015, 12:10 AM   #31
dmark101
dmark101's Avatar
which yard did you go to?
i still find a decent amount down at the wilmington yards. don't see too many up in ontario or san bernadino.
Old December 6th, 2015, 08:15 AM   #32
Eric351M
I went to Ontario and Riverside
Old December 6th, 2015, 10:43 AM   #33
dmark101
dmark101's Avatar
yeah, i had a feeling those were the two you went to.
keep in mind that you can also grab the pulley from a 626 as well. if you find one, always keep both a 16mm and a 32mm pulley on hand. everywhere i looked, the larger bore water pump was actually less expensive that the smaller bore.
go figure.
Just Acquired a Free 94 4X4 Blazer, Woot! Tommy Probe Lounge 29 December 31st, 2009 02:05 PM
My newly acquired '95 GT spada Probe Pic & Video Post 9 September 14th, 2009 02:53 PM
Recently Acquired shockthaworld2 Appearance Section 6 January 25th, 2007 10:24 AM
96 Ford Service CD Acquired 190km/h 2nd Gen (93-97) V6 2.5L 7 January 1st, 2002 10:37 AM
acquired experience? eunosads Probe Lounge 7 October 24th, 2001 09:53 AM
