Old August 9th, 2017, 03:54 AM   #26
I second blue's clues above ^^^
KLZE Porsche is offline   Reply With Quote
Old August 9th, 2017, 05:53 AM   #27
shdtree95
180 degrees out
Blue - this makes sense. I may be at TDC on exhaust stroke - I will rotate crank one full turn so that distributor engages and give it another shot and make sure rotor is pointing to No 1 plug terminal.
Thanks
my email address is NOT working!
shdtree95 is offline   Reply With Quote
Old August 11th, 2017, 10:20 AM   #28
shdtree95
Update
Well - I was going to test for spark again with an assistant and the starter solenoid finally failed after 22 years, not too bad. The plugs are covered with gas and car just sputters a bit. Letting the motor air out as I won't get the solenoid until tomorrow. Since the overcharging alternator was the source cause of this entire adventure and I still have it in the car, I put a test light on what appears to be the power lead and I get no light. I have a replacement, just wanted to make sure the car runs before putting it in. Unless this failed piece may be keeping the car from starting?
Any input on this?
Thanks,
Old August 11th, 2017, 10:51 AM   #29
What's the status of that rear cam pulley?
Old August 11th, 2017, 12:12 PM   #30
shdtree95
Update
Have not removed timing belt cover - but I can check that.
Old August 11th, 2017, 04:39 PM   #31
You may be able to check it by getting most of the bolts out of the cover and pulling it back. You'll probably need a hand, turning the engine over by the crank and holding open the cover so you can see if that bolt spins with the pulley.
Old August 13th, 2017, 09:42 AM   #32
shdtree95
Update
The car fired up. Went back and reset my initial timing after some adjusting, hit the right spot and it started easily. Thanks to all for your input along the way. None of my gauges work, tach, oil pressure, water temp, etc... Does anyone know how these are controlled?
Thanks,
Old August 13th, 2017, 01:08 PM   #33
shdtree95
Update
Thanks,
Old August 13th, 2017, 04:39 PM   #34
For the gauges not working... Do you have a power antenna, and do your reverse lights work. Check your fuses. Above the transmission there are reverse light wires (both green I think) that get frayed and short out on the trans, caused my gauges to go out on my 95. Of course they're not easy to see or get to.
Old August 15th, 2017, 05:27 PM   #35
shdtree95
Gauges
I replaced blown 15A meter fuse and I now have gauges. Have to diagnose why tach is not working.
Old August 16th, 2017, 08:35 AM   #36
You should also look for why the fuse popped.
Overcharging Problem, Help! snowfire814 2nd Gen (93-97) V6 2.5L 7 February 27th, 2011 02:58 PM
Overcharging.Alternator? TrakTuned 2nd Gen (93-97) V6 2.5L 10 August 1st, 2010 11:25 AM
overcharging.....help ksatria Michigan Probe Owners Club 0 November 5th, 2002 08:57 PM
alternator-overcharging-the-battery osofast 1st Gen (89-92) All 5 May 31st, 2001 01:55 PM
alternator-overcharging-the-battery osofast 1st Gen (89-92) All 2 May 30th, 2001 02:49 PM
