what needs to be done so it works correctly together?
KLDE throttle body on KLG4 manifold.
alot
or you can get a kl47 TB from a millenia, file it down and slap it on.
KL01 TB will hit the metal coolant lineLeo
94 PGTze - sold vid 1 vid 3 vid 2
98 Pontiac firebird formula WS6 the race car.
95 PGT-T..AKA..The ReD GhoSt KLDE turbo Built by me ..sold
get an outlaw engineering tb spacer. then you dont have to modify the tb at all. if not then get a dremel with a metal grinding bit. i used one that looks like a mini drill bit and it worked great. but if you try to mate the two together you will see where it hits. theres a part that sticks out right below the mating surface on the tb. that must be grinded down about 1/2 to 3/4" or so until it clears the mani
edit: about the tb hitting the metal coolant line. its the iac plug that hits with the de iac. yer best bet is getting a ze iac and modding the de tb. though i got mine to fit by taking the plastic quick disconnect connector off and just running the hose to the metal tube with a clamp. should give you just enough space to clearLast edited by mikexmayhem; October 13, 2010, 05:46 PM.1996 pgt - 148k miles
milly maf conversion, klg4 intake mani(need a new one!), stage 1 clutch, mx3 flywheel, many other mods
i did the grinding already, and it mates up perfectly and looks like it belongs because i only did the part of the tb that hits the manifold.
so just looking at it, it looks stock.
im wondering what other mods need to be done to make it work as far as fitment to the motor.
EDIT: i already took the plastic crap of that fitting when i did my atx to manual swap.
what about the 1 inch fitting on the TB? what needs done with that?Last edited by ameadows32; October 13, 2010, 05:48 PM.
nothing. the manifold bolts right on. you may have a difficult time getting both bolts in the throttle cable bracket. i just used one and it works just fine. other than that its bolt on1996 pgt - 148k miles
correct. you will need to find a way to connect it to the manifold so the air can get past the throttle plate during idle. i spliced mine into the pcv line that goes right over the top of the mani. but like i said previously you can get a ze iac and get rid of the nipple. drill a hole in the de tb (or i have a ze tb if you want) and it will function correctly1996 pgt - 148k miles
yes it is. but the airflow goes from the vc to the manifold so the air from the iac will follow to the mani. it will work temporarily. you will get alot of oily build up inside the tube. it is better to get a ze iac to not have to run tubes all over the place and keep it clean and not have to mess with the pcv line1996 pgt - 148k miles
for the vacuum nipple near the TB to work, you should get a curve neck (KL47) TB.
the hose going over the top of the IM is for the PCV.95 GT-ZE (Snow white)
http://s815.photobucket.com/albums/z.../Snow%20white/
http://www.cardomain.com/id/93mazdapgt
