Dyno Run Results Database
  • Dyno Run Results Database
    This thread is dedicated to roughly answer the question, "How much power does my car make?" Many people post up asking, "How much power does such and such mod make?" or "I have done [these mods] how much hp does my car make?"
    Before you start posting it would be good to know what modifications you have on your car and other details of your car as follows:
    -Year (e.g. 1995)
    -Make and Model (e.g. Ford Probe GT)
    -Transmission (MTX or ATX)
    -Mileage on engine (e.g. 59k miles)
    -Type of engine (KLDE/03, KLZE, FS03, Hybrid [03 block ZE head], custom, etc.)
    -Power mods only (e.g. KLZE, AFPR, fuel pressure settings, CAI, headers [brand included], exhaust [piping size], port and polishing, nitrous [brand and shot], turbo or S/C, chips, stand alone, etc.)
    -Other misc parameters (temp and humidity during testing, ignition timing [if known], wheel size, etc)
    -Brand of Dynomometer (Mustang or DynoJet usually...Mustang dynos will produce numbers ~10-15% less than a comparable DynoJet Dyno for the same car)
    -Elevation of the city where you dyno'd (Data can be found here--> www.city-data.com )
    If you have a dyno plot scanned in that would be great. Just link it into the post. Images unfortunately cannot be added inline in this forum. In case your picture goes down, be sure to type in the wheel horse power and wheel torque (wtq=ft-lbs) you got on your dyno so that we know what you got even without the pic. For example, whp=135.5 wtq=133.8
    Lastly, do not post up the following:
    -guesses as to what you think your car can do on a dyno
    -no G-Tech results
    -no fake dynos
    -no discussion posts
    -no arguements
    If you want to discuss a dyno, the poster may add a small dyno explanation, but any further dyno discussion should be done in a separate thread.
    The more dyno runs that you can include the better.
    Marc M.
    2000 BMW M-Roadster
    Date: 10-27-2003
    Elevation: 696 feet (as per www.city-data.com )
    -1995 Ford Probe GT MTX 58k miles
    Engine: stock '95 PGT KL03 engine/heads/cams, 58k miles, NGK V-power plugs, Magnecor 8.5mm wires, stock ignition, stock FPR
    Mods: PRM intake, HotShot TB elbow, KLZE intake manifold (not modified), Outlaw Engineering KL03 phenolic spacers (port matched to the ZE IM on the IM side), 65mm TB, TB phenolic, TB coolant bypass mod, Brospeed Headers, EGR capped, 2.25" test pipe, Borla cat-back, UO UDP, Fidanza FW, mikeseli ZE VRIS ECU
    Misc: SBC DXD FF clutch, stock swirlies with Kumho 712 225/50-16, front end alignment seemed a bit off, Mobil 1 Synth engine oil 5w/30, Royal Purple GearMax 75w90 MTX fluid, base timing 6* BTDC
    Dyno: DynoJet Dyno 4th gear pull
    Temp ~65*F low humidity
    Results:
    Run #1: whp=160.1 wtq=154.6
    Run #2: whp=159.8 wtq=154.5
    Run #3: whp=160.5 wtq=154.8
    Dyno printout:
    http://home.comcast.net/~mmunoz70/z/20031027omaha01.jpg
    Y-axis stretched and edited version
    http://home.comcast.net/~mmunoz70/z/20031027omaha02.jpg
    Discussion: The print out was pretty crappy. The guy at the shop didn't know how to reduce the Y-axis on the graph so it's kinda squished, base timing was figured out later when I finally got around to checking my timing. Also, I don't recommend Royal Purple tranny oil. Very crappy in the winter and worse than Redline MT-90 or even stock tranny oil. I switched to GM Synchromesh later on...wow what a difference
    Marc M.
    2000 BMW M-Roadster
      Time Traveler's dyno runs added below
      Marc M.
      2000 BMW M-Roadster
        Date: 9-12-2003
        - 1994 Mazda MX-6 LS - MTX
        - 116k Miles
        Engine: Stock 1994 MX-6 KL03 engine, NGK V-power Plugs, Sparco Racing 9mm Wires, Stock Fuel
        Cams: KLZE cams (Intake/Exhaust)
        Intake: Hotshot Cold Air Intake w/ Elbow, 65mm TB, StreetThisTuning KLZE Intake Manifold, Outlaw Engineering KLZE Phenolic Spacers, TB coolant Bypass Mod
        Exhaust: Pacesetter Headers, EGR Capped, 2.5" test pipe, 2.5" Crush Bent Exhaust Piping, Magnaflow Race Series Muffler
        Misc: UR UDP, Fidanza 9lb FW, SPEC 6 Puck Racing Clutch, Finishline ZE VRIS ECU, Air Conditioning Removed, Stock MX-6 LS Rims w/ Dunlop Sp5000's 205/55-15
        Temp ~70*F Mild Humidity
        Results:
        Big Shot Dyno - 4th Gear Pull
        WHP=170.7 WTQ=167.7 (Before ZE IM Install)
        Dyno printout: Click Me
        WHP=185.1 WTQ=169.1
        2006 Evolution IX - Best ET: 8.92 // Best MPH: 166.85
          10-11-03
          turbo @13psi, standalone, stock bottom end, stock heads, fuel mods etc.
          368whp
          351lb-ft wtq
          proof
          NCPOC > BAPOC > SCPOC > FlaPOC > MIPOC
            Time Traveler's (Jin Kim's) Dyno runs
            Car:
            -1995 Ford Probe GT MTX ~49k miles
            Date: Run#1=03/20/98 Run #3=06/03/98
            Run#1 mods: None, completely stock run
            -Castrol Syntec motor oil
            Temp 70.4*F
            Run#3 "mods": Magnecor KV85 wires
            Misc: Redline Watter Wetter additive to 50/50 coolant, Redline MT-90 MTX, Mobil 1 synthetic motor oil, everything else stock.
            Temp 72.5*F
            Results:
            Run #1: whp=133.1 wtq=136.9
            Run #3: whp=136.9 wtq=138.4
            Dyno printout: http://www.chrono.org/dyno01.htm
            Marc M.
            2000 BMW M-Roadster
              Date of Dyno - 10/15/03
              -Year - 1996
              -Make and Model - Ford Probe GT
              -Transmission - MTX
              -Mileage on engine - 78k miles
              -Type of engine KL03 Hybrid (03 Heads/ZE IM
              -Power mods - ZE IM, Phenos, 65mm TB, Underdrive Pulley. Clutchmaster Stage II-R and Fidanza, Cosmo FPR
              -Other misc parameters - Dyno'd in South Florida on a very hot day with the stock 16" Chrome Swirlies on the car.
              -Brand of Dynomometer - DynoJet
              whp=159.4 wtq=149.0
              http://mindspring.com/~hppwdn/dyno10-15-03.jpg
              Adjusting the fuel pressure gave major gains on the dyno. About 10HP from the first to last run. The first three runs were in fourth gear, and the the last was in third gear.
              92 MX3 Turbo ($100 junkyard KLG4) 11.904 @ 124.3mph, 14psi, DOT approved Hoosier drags, pump gas.
              HIN/NOPI Supershow Class Winner - Miami 2010 - Street-Sport Compact-Mazda
              Links: Pretty Pic, GoFast Pic, Timeslip, Track Video, Dyno Video
              As of July 2011 the MX3 has been retired and sold.
                Date: 06/03/98
                Car: 1995 Ford Probe GT MTX ~49k miles
                Mods: Magnecor KV85 plug wires, Hotshot Cold Air intake w/K&N RE-0930 cone filter
                Misc: Mobil 1 synthetic motor oil, Redline MT90 synthetic MTX oil, Redline Watter Wetter radiator additive
                Results: whp=141.0 wtq=141.1
                Dyno printout: http://www.chrono.org/dyno02.htm
                Marc M.
                2000 BMW M-Roadster
                  Date: 06/03/98
                  Mods: Magnecor KV85 plug wires, Borla SS Cat-back exhaust
                  Results: whp=138.5 wtq=140.7
                  Dyno printout: http://www.chrono.org/dyno03.htm
                  Marc M.
                  2000 BMW M-Roadster
                    Date: 06/03/98
                    Mods: Magnecor KV85 plug wires, Borla cat-back exhaust, Hotshot Cold Air intake w/K&N RE-0930 cone filter
                    Results: whp=143.0 wtq=145.5
                    Dyno printout: http://www.chrono.org/dyno05.htm
                    Marc M.
                    2000 BMW M-Roadster
                      Date: 06/16/98
                      Mods: Magnecor KV85 plug wires, Borla cat-back exhaust, Hotshot Cold Air intake w/K&N RE-0930 cone filter, Unorthodox Racing under drive pulley (UDP)
                      Results: whp=142.5 wtq=145.2
                      Dyno printout: http://www.chrono.org/dyno07.htm
                      Marc M.
                      2000 BMW M-Roadster
                        Date: 06/16/98
                        Mods: Magnecor KV85 plug wires, Borla cat-back exhaust, Unorthodox Underdrive Pulley, Hotshot Gen III Headers, (Stock intake)
                        Results: whp=144.6 wtq=148.4
                        Dyno printout: http://www.chrono.org/dyno09.htm
                        Marc M.
                        2000 BMW M-Roadster
                          Date: 06/25/98
                          Mods: Magnecor KV85 plug wires, Borla cat-back exhaust, Unorthodox Underdrive Pulley, Hotshot Cold Air intake w/K&N RE-0930 cone filter, Hotshot Gen III Headers
                          Results: whp=149.3 wtq=153.3
                          Dyno printout: http://www.chrono.org/dyno10.htm
                          Marc M.
                          2000 BMW M-Roadster
                            Per Omaha95PGT's request:
                            '94 PGT MTX, approx. 80K-90K on the clock, full KL-03, Dynojet dyno, stock wheels. Ran on 12/2000, 03/2001, and 06/2001.
                            150.4 hp/153.3 tq http://www.sunflower.com/~jmshultz/dyno1.jpg - First Dyno: After fixing my VRIS. Mods: 60mm mandrel bent catback, HS intake, UDP, lightened stock flywheel, pheno spacers, ACT2 clutch
                            http://www.sunflower.com/~jmshultz/dyno2.jpg - Second Dyno: Comparo of before and after fixing the VRIS. When it was broken, the VRIS was closed at all times, and notice I was losing over 25hp and 25 tq in a fat chunk of my midrange...
                            159.8 hp/159.1 tq http://www.sunflower.com/~jmshultz/dyno3.jpg - Third Dyno: Same as the first dyno, except added Pacesetter headers and got rid of the cat and put a resonator in its place. The I.D. of the resonator was smaller than the catback so I was probably losing a small amount of power on that...
                            http://www.sunflower.com/~jmshultz/dyno4.jpg - Fourth Dyno: Comparo with dyno 3 where I tied open the VRIS at all times (dyno run on the same day). I actually lost power everywhere!
                              Garrett Stage III T3/To4e turbocharger .50 A/R compressor; .63 A/R turbine
                              TiAl 35mm external wastegate
                              24x7x3" Front-mount intercooler with 18" core
                              Clutchmasters Stage II-R 300lb/tq Clutch
                              MSD 6a Ignition
                              Fidanza 7.5lb Flywheel
                              Cartech FMU
                              Walbro 255lph Fuel Pump
                              Holley 75GPH In-line fuel pump
                              Weld El manifold
                              2.25" downpipe
                              2.25" intercooler and turbo piping
                              GReddy Type S BOV
                              3" intake pipe with air filter
                              NOS N20 Sprayed over intercooler
                              Custom Made 2.5" cat-back exhaust
                              Pacesetter Muffler
                              High-flow Catalytic Converter
                              Cone Filter
                              Rebuilt Transmission (Strengthened 1st, 2nd, 3rd gears)
                              GT 5-Star Wheels
                              1997 2.0L
                              These are 3 pulls on 3 different occassions
                              Pull 1 @4psi untuned slipping stock clutch/flywheel, restricted exhaust (a 2" section)
                              whp=141 wtq=150 - Dyno Jet
                              http://www.squirrelsw.com/probe/dynosmall.jpg
                              Pull 2 @4psi tuned upgraded clutch/flywheel, open downpipe
                              whp=171 wtq=184 - Dyno Jet
                              Pull 3 @9psi tuned, with n20 over intercooler, bigger fuel pump, custom big exhaust/cat-converter, new TPS/o2 sensors, egr plugged
                              whp=212 wtq=233 - Mustang Dyno
