Go Back   ProbeTalk.com Forums > Tech Section > Racing/Suspension
Racing/Suspension Drag Racing, AutoX, Road Racing and Suspension.
Old May 16th, 2010, 10:46 AM   #26
JKpgt96
Drives Light Blurple Car
JKpgt96's Avatar
Originally Posted by EloM View Post
I've read through this thread & it seems to have gone dead.
Can anyone update the status of the info that was being asked here? Whether we can use Protege lateral links instead.
I am in the market for replacing my lateral link bushings so I can get my alignment done, as my rear end is ever slighty out that it's not ruining my tires & don't want to buy the new arms from Mazda @ $82ea.
Also, if so & I went with the protege trailing arms, what difference would I see in the ride & cornering? Better or worse? I have the AWR 19mm rear sway bar & stock 225 tires.
Why not use the Probe/mx6 trailing arms?
John Kessler - 'The Original Mayonnaise'
'95 Probe GT- Blurple-ish, SSR Integral A2s, D2 Coilovers, Renault Laguna Lip SOLD
'96 Probe GT-Bolt-Ons, MS1 v3.0, Custom Suspension, The original Tri-Flow Turbo Cams, etc..Sold, and missed
New? From Missouri/S. Illinois/Kansas area? Let me know!
'95 M3/2/5-S366 2J Swap in progress
JKpgt96 is offline   Reply With Quote
Old May 17th, 2010, 04:46 AM   #27
reuben_johnston
reuben_johnston's Avatar
my setup has the probe/mx6 trailing arms.
1996 mazda mx6 m edition
reuben_johnston is offline   Reply With Quote
Old May 17th, 2010, 06:18 PM   #28
EloM
There's nothing wrong with my trailing arms, just saw that it sounds like the protege ones are an upgrade?
But really, I need the lateral link bushings. Anyone have an idea if there's something else we can use or for the Aussie's that have access to Nolathane, anyone know a part #?
93 PGT Electric Blue
Sold
KL-Z(zed
)E, Stoker100 Chipped
, OBX headers, JJ TP, 67mm bored TB, CAI, CM#2, MX-3 FW, Ultimate STS, Homemade Grounding Kit, AWR Sway Bar, Rear Protege Calipers, Magnaflow 12245 (best muffler ever!)
2006 Subaru Legacy Wagon
EloM is offline   Reply With Quote
Old June 13th, 2010, 10:27 AM   #29
unionrdr
unionrdr's Avatar
Sorry to keep flailin a dead horse,but I'm trying to finalize all this in my head. It looks like some type of "arms" are being used in pairs to replace the rear control arms,yes? Would these "arms" be "lower arm bars" as sold on corksport.com for the 99-'03 protege? They sell'em at $145 usd each. I def want this adjustability for my PSE,as it's out now after being lowered,& no one knows how/or will do what the car needs to git-r-right. It'd be great to take a socket wrench & a tape measure/bubble level to it & DIM!
'94 PROBE SE Middle-aged croozr
unionrdr is offline   Reply With Quote
Old July 18th, 2010, 01:58 PM   #30
MSDKLZE
Turbo Junkie
MSDKLZE's Avatar
so I have been researching this "Nolathane" stuff and I can only find bushings for the trailing arms. Thats not what I need though. What I require is the bushings for the four "lateral links". I cannot seem to find replacement bushings or arms. My arms themselves are not bent, so I could re-use them. But the bushings are rotten, so I need those badly. Can anyone point me to the right spot to buy them?
Also, i looked all over AWR's site and could not find them there either.. help!
DRIVE IT LIKE YOU BUILT IT!!
MSDKLZE is offline   Reply With Quote
Old July 18th, 2010, 06:52 PM   #31
gonen2
Make your own.
97 red PGT-ZE
gonen2 is offline   Reply With Quote
Old July 18th, 2010, 09:03 PM   #32
MSDKLZE
Turbo Junkie
MSDKLZE's Avatar
^ explain.
Old July 18th, 2010, 09:12 PM   #33
Rebelwolf
Rebelwolf's Avatar
I think what gonen2 means, is to make your own lateral links. All you have to do is get some Heim joints, and a bar that goes in the middle that is threaded female at both ends. I have the same plan to make the end links you see in the photo of the car with that setup. All you would have to do is measure the length of the lateral links hole to hole, and subtract out some of the joint's length to get a DIY Lateral Link.
US ARMY Disabled Veteran
1994 PGT - CAI, 10.2mm Wire, NGK, HEI, Bi-Xenon HID Projectors, 17mm Ford Contour rear sway bar, Cooper CS4
OSX 10.7, iPhone 4, Cannon Rebel XS
Rebelwolf is offline   Reply With Quote
Old July 18th, 2010, 09:23 PM   #34
Stevoh
Yep I plan on doing this too. Just need to know the size of the bolt also so you can size up the heim ends correctly. I know jk96pgt said he was gonna get some measurement and also do a write up about them but haven't seen anything. I think I'll PM him about it sometime. Not too much in a hurry to get em yet.
Also to help you find the connectors look for: "connector rods/tube" or "swedged rods" if I remember correctly in correspondance with searching for heim joint ends. I had a hard time finding the the rods but an easy time finding some of the heim ends. Not sure if anyone has run into this as well.
Chameleon Blue 95 PGT 5 Speed
Primered 89 PGT 5 Speed
Black 97 BMW 540i 6 Speed
Stevoh is offline   Reply With Quote
Old July 18th, 2010, 09:43 PM   #35
Rebelwolf
Rebelwolf's Avatar
The HEIM End Joints are also called Rod End Bearings.
Old July 19th, 2010, 09:56 AM   #36
MSDKLZE
Turbo Junkie
MSDKLZE's Avatar
I would make my own if I could, but I do not have such resources for fabricating and i do not want "heim joints". I want urethane bushings so it can have a wee bit of give when driven hard.
Old July 19th, 2010, 10:31 AM   #37
JKpgt96
JKpgt96's Avatar
I was supposed to take the measurements on my stuff this weekend, but didn't. I will this week and post them up. Its just a matter of buying the pieces, there is really not any fabrication needed.
Old July 19th, 2010, 02:24 PM   #38
Rebelwolf
Rebelwolf's Avatar
I measured the rear rear lateral link and it was about 1' 11'', or 23". Rear forward link looks to be a bushing type link, and I forgot the measurement of that one, maybe like 4" less I think? I think you would be safe if you got a link that is extendable to 25 or 26" from a starting length of 21".
Old March 21st, 2017, 06:42 PM   #39
reuben_johnston
Well, it has been, like forever, but I installed some items last weekend (dissertation+work+parenting). The lateral links are finally installed on my 96 M edition with K-sports, but I need to adjust and check fitment on the ground. I also need to test fit the swaybar fitment. Hopefully, I'll be able to do that this weekend and snap some pictures!
REub
Old March 21st, 2017, 09:20 PM   #40
Mike 99
Mike 99's Avatar
Holy resurrected thread, Batman! 7 year hiatus, then brought back by an original author no less!
Excellent! This may just be a record.
Mike 99 is offline   Reply With Quote
Old March 23rd, 2017, 05:20 PM   #41
93lazerpgt
Good to see that the project was finished so many never get finished anymore
93lazerpgt is offline   Reply With Quote
Old March 25th, 2017, 04:27 PM   #42
Mike 99
Mike 99's Avatar
I should have also offered congratulations, something I would also like to do one day. New engine build first.
Old March 26th, 2017, 06:07 PM   #43
reuben_johnston
Ran into some delays fitting the swaybar today and was not able to snap pictures. Hopefully next weekend.
REub
Old April 1st, 2017, 06:35 PM   #44
reuben_johnston
Ok, I was able to fit everything today! I'll try to snap some pictures tomorrow for a writeup. This setup has Ksport Kontrol Pro's for a protege, AWR lateral links for a protege, AWR trailing arms for a MX6/Probe, AWR 21mm anti-swaybar for a protege, AWR end-links for a protege.
REub
Last edited by reuben_johnston; April 1st, 2017 at 06:38 PM. Reason: website error with protege accent marks, wtf
Old April 1st, 2017, 07:45 PM   #45
93lazerpgt
Looks like you can't buy the lateral links from AWR anymore but King6 still sells them
93 PGT CAI, Egay headers, high flow cat. 2.5 mandrel bent with Borla, Yonaka coilovers,19mm rear bar,CM 12lb fly and stage 2 clutch
She tends to argue with me daily...yep it's a Probe
Old April 2nd, 2017, 03:49 AM   #46
reuben_johnston
Yes, AWR does not list the lateral links on their site anymore. The nice feature about these lateral links for autocross applications are the spherical bearings. The King6 lateral links are a nice alternative, but they use poly bushings (which will be better for street applications).
REub
