Go Back   ProbeTalk.com Forums > Tech Section > 2nd Gen (93-97) I4 2.0L
2nd Gen (93-97) I4 2.0L Discussion of Maint Issues for I4
Old January 8th, 2017, 09:30 AM   #1
Moose16
96 Probe intermittently stuttering/shuttering at all speeds
Hello,
I have a 96 SE (my 2nd 2.0) and I'm having an issue that just started a few weeks ago where the car will stutter hard as if the key were momentarily shut off and this happens at random at any speed. Sometimes it happens once, sometimes it happens 2,3,4 times in sequence. I can't really find any consistent patterns or triggers. Any suggestions?
My thoughts were to look at the MAF and TPS but I would think those would be a more consistent rough running issue, when the car doesn't stutter it's fine. It just feels like it shuts down then comes back to life. Battery connections appear to be solid, my old one used to stall momentarily because the negative terminal was loose but don't think that is the case here and this has more of a bucking/jerking feeling. My mechanic said he couldn't reproduce it but don't think he really tried. Any suggestions are appreciated. Thanks.
Moose16 is offline   Reply With Quote
Old January 8th, 2017, 10:14 AM   #2
panic37
First things first I'd check all your grounds. Not just where the terminal connects to the battery. Get some sand paper and make sure everything has good contact. Wouldn't hurt to even add an extra ground. I've always had luck getting a short ground cable from AutoZone and attaching it under a fender bolt and to the negative terminal.
panic37 is offline   Reply With Quote
Old January 11th, 2017, 11:24 AM   #3
livingsacrifice
livingsacrifice's Avatar
Clean the MAF out as well. That's something I recall from doing maintenance on the old probe
2016 Subaru WRX Premium
for sale soon
GONE
livingsacrifice is offline   Reply With Quote
Old January 11th, 2017, 12:33 PM   #4
Probesport
20 years of Probin'
Probesport's Avatar
Excuse my old guy memory, but did the 2.0 suffer from igniter failures like the 2.5? If so, this sounds a lot like it.
Chrome wheeled, fuel injected, and steppin out over the line
PRD - The original Ford Probe Aftermarket, THANK YOU FOR THE GOOD RUN
1999-2013 : 14 Years of supporting the Probe community
| 2005 VW Touareg V8
Probesport is offline   Reply With Quote
Old January 12th, 2017, 10:49 AM   #5
Silverprobe
Fuel filter needs changed?
Silverprobe is offline   Reply With Quote
Old February 9th, 2017, 03:48 AM   #6
93lazerpgt
Would also check to see if there are any stored codes. Just because the CEL isn't on doesn't mean there's no codes
93lazerpgt is offline   Reply With Quote
Old February 18th, 2017, 10:32 PM   #7
96PGT_OH
Is the sputter just on takeoff?
If so my issue albeit on the 2.5 was the distributor. On takeoff when you have it gas it fell flat on its face like a drunk on new years but if you eased into it no problem after you got going.
#1- 96 PGT MTX- Demoted to Parts car
#2- 96 PGT ATX
-New Daily
96PGT_OH is offline   Reply With Quote
Old July 18th, 2017, 11:15 AM   #8
diosnoche
vacuum leaks, cracks in intake hose from MAF to Throttle body maybe?
diosnoche is offline   Reply With Quote
HELP!: 4WS fails intermittently after engine swap andrewb 2nd Gen (93-97) V6 2.5L 19 November 20th, 2007 02:51 PM
Shuttering during enguagement racer495a 2nd Gen (93-97) V6 2.5L 4 April 22nd, 2007 08:31 PM
shuttering PepperBoY 2nd Gen (93-97) V6 2.5L 5 November 10th, 2004 02:12 PM
93 Base intermittently stuttering hesitating xadawgx 2nd Gen (93-97) I4 2.0L 13 January 26th, 2004 10:12 AM
Brake Problem plz help(shuttering) carbine 2nd Gen (93-97) V6 2.5L 5 July 27th, 2001 02:41 PM
