Torque Specs
  • Torque Specs
    • Camshaft Cap Bolts
      125 inch lbs
    • Camshaft Sprocket Bolts
      44 ft lbs
    • Connecting Rod Bolts
      19 ft lbs
      90 degrees
    • Crankshaft Sprocket Bolt
      116-123 ft lbs
    • Cylinder Head Bolts
      16 ft lbs
      90 degree turn
      90 degree turn
    • Exhaust Manifold Nuts
      15-20 ft lbs
    • Exhaust Manifold Bolts
      12-16 ft lbs
    • Flywheel Bolts
      71-76 ft lbs
    • Intake Manifold Bolts
      14-18 ft lbs
    • Main Bearing Cap Bolts
      16 ft lbs
      90 degree turn
    • Oil Pan Bolts
      18 ft lbs
    • Oil Pump Bolts
      19 ft lbs
    • Spark Plugs
      11-16 ft lbs
    • Timing Belt Cover Bolts
      95 inch lbs
    • Waterpump Bolts
      19 ft lbs
    1994 Ford Probe 2.0L MTX
    1996 Mazda 626 2.0L MTX
    Cardomain - Needs updating.
