Go Back   ProbeTalk.com Forums > Performance Section > Engine Electronics
Engine Electronics Do you own a Jacobs, MSD, MegaSquirt or other ignition/fuel system? Get in here and ask your questions!
Old January 26th, 2016, 12:14 PM   #201
ChillinZX
The default map is set at 12 something and under a/f. Sounds normal, the extra fuel probably keeps the temp down. You can adjust it manually if you want, say 13 to 14 or so. I deleted my IAC, so I just adjust the screw on top if my idle is too high or low.
2000 ZX2 w/ '95 Millenia KL swap, MSPNP (VAF delete, IAT mod, AEM Wideband, Coilpack), MFactory LSD and 'Plate Mod' 626 trans, Aeromotive fuel system, custom DSS 500hp axles, AWR solid trans mounts, KLG4 IM, MX3 GS brake booster/master combo, ebay headers, ebay CAI system, Ford Racing ZX2 inverted coilovers, Cusco camber plates all around, custom made traction bars mounted to frame rails, body kit, 2 tone paint, etc...
ChillinZX is offline   Reply With Quote
Old February 3rd, 2016, 09:04 PM   #202
gavinegr
Great resource!
gavinegr is offline   Reply With Quote
Old March 29th, 2017, 04:14 PM   #203
Just wanted to update this thread with some tunes:
http://members.iinet.net.au/~steven.s/
stoker100 2017= my current tune as of right now
-MSD
-36-1 wheel
-No VRIS
-WMI control
-Mill S inj
NA 2015= my last tune before boosting (has some boosted VE/Timing but that's easy to change)
-MSD
-Stock crank wheel
-Stock injectors
-VRIS
^ for you proboner!
Nitrous oxide. - 79' Yamaha QT50 'Yamahopper' 70cc, MLM pipe, VM18 carb, dual stage reeds etc.
Old April 10th, 2017, 10:11 AM   #204
BlackProbe
-MSD
-36-1 wheel
-No VRIS
-WMI control
-Mill S inj
-MSD
-Stock crank wheel
-Stock injectors
-VRIS
^ for you proboner!
Why did you switch the the 36-1 wheel??
93 Probe gt- ,15.37 1/4 mile at mph 85 ** 5/24/03 14.71 SOLD
1994 gt -klze,I/h/e/fly/ignition/kl31 ecu,colt210/210 cams Rip 2/13/08(blackice)
92 mx3gs,ze swap from my probe 15.0@96mph :-( 175hp&155tq
BlackProbe is offline   Reply With Quote
Old April 10th, 2017, 05:32 PM   #205
It was on the crank SC OD pulley.
Old April 29th, 2017, 04:44 AM   #206
Probomax
Spark maps
Does anyone have some good spark maps for NA?
The Megasquirt baseup maps are for turbo and I' trying to figure out what a good map for NA would look like.
Probe GT 4WS!!! with KLZE heads & manifold, Megasquirt, OE spacers, ebay headers & RX8 steering wheel
Probomax is offline   Reply With Quote
Old May 2nd, 2017, 01:40 PM   #207
Matt Cramer
Authorized PT Vendor
Matt Cramer's Avatar
The MSPNP base map was tuned on a naturally aspirated KLZE.
http://www.megasquirtpnp.com/mspnp2_maps.php
Matt at
My PM box fills up fast - it's much better to email me at
Matt Cramer is offline   Reply With Quote
Old June 15th, 2017, 10:37 AM   #208
Unless I'm just somehow looking at the wrong thing, the map there goes well above 100kpa, suggesting that it's for FI. Also, timing at 100kpa is at like 22*, which seems a bit low for NA at WOT...
proboner is online now   Reply With Quote
Old June 20th, 2017, 07:42 AM   #209
Matt Cramer
Yes, we put some cells in boost on the map because we anticipated a lot of customers would be using the MSPNP for turbo motors. The map was meant to be a starting point. As such, I think it's got a degree or two pulled out. That said, like most modern engines, KLZEs don't like a lot of timing compared to muscle car era engines.
Matt at
Old July 3rd, 2017, 09:57 PM   #210
spada
ProbeTalk MC
spada's Avatar
I beg to differ on that last remark about it not liking timing.
On 93 octane, it wants 29 degrees at max torque RPM
On 87 octane, it can still handle 27 degrees at max torque. I've dyno tuned just the timing after fine tuning the fuel. I started at 32 degrees and found the top of the parabola. I then called Corksport to talk with their KL race engine tuner. I wish I could remember his name. It was something exotic like Alistar or something. His words were along the lines of "the KL loves 29 degrees. That's what we run for maximum power." That confirmed my findings. Then I shared my findings with the community, and shortly after, everyone running MSNS on NA KLZE's were hitting their highest dyno numbers. Most people were using my entire timing map and I still see likenesses to my maps in almost every KL map I download.
1996 Boysenberry Probe GT MTXtreme
2014 Fusion SE MTXtreme
2005 Mountaineer Premier
spada is offline   Reply With Quote
Old July 5th, 2017, 09:32 AM   #211
Matt Cramer
Unfortunately, the tuner who set up that map no longer works here, so I'm not able to check with him on the exact origin of the map. It may have been that he'd combined a tune from a stock KLZE with the timing map from a turbo KLDE that we had tuned at a different time.
Matt at
Old July 6th, 2017, 11:50 AM   #212
yellow2point0
yellow2point0's Avatar
Matt, I'm about to fire up this PGT running the newest MS3-Pro Ultimate. Pretty darn excited! I'll post my tables soon, guys. I have access to a dyno and tuning here at the University of Northwestern Ohio :-)
Love, love, love all the inputs and outputs of the MS3-Pro! Even check engine light works on my stock PGT dash :-D
1995 Ford Probe GT, black - Garrett GT3076-R @ 11.2psi. ~321ish whp/303ish wtq @ 19-20○ ignition, DIYPNP MS2/extra, etc. -parted & junked
1995 Ford Probe GT, black - MS3-Pro Ultimate, bone stock-ish, daily driver)
yellow2point0 is offline   Reply With Quote
Old October 21st, 2017, 07:38 PM   #213
spada
ProbeTalk MC
spada's Avatar
Here are the maps from my 96 Probe GT.
The fuel map has been dialed in with a wideband. most of the fuel map is at 14.7:1 until it gets to 70 kpa, then it goes to 13.5:1, and at 80kpa it goes to 13.0:1. Open loop begins at 70kpa.
There's a ramp up near idle to be around 13.2:1.
Old October 24th, 2017, 06:05 AM   #214
Greg 94 PGT
Greg 94 PGT's Avatar
Anyone have any information on startup tables and values?
Now that my PGT is up and running I've been driving it around and working out bugs and everything seems pretty good.
But one thing that bothers me is the startup. When I start it, it cranks and catches fine, but once it starts the revs jump to 2,000 - 2,500 rpms and hang there for a few seconds and then slowly come down to a normal 1k during warmup.
I know I've read in the past about adjusting that area, but I can't recall what the table/section is called.
'94 Red PGT Gone, but Project PGT has begun
'04 Black SRT-4 Um, no it's not stock. But "It's just a Neon, right?"
379whp @ 20lbs *Sold*
Greg 94 PGT is offline   Reply With Quote
Old October 24th, 2017, 10:31 AM   #215
spada
ProbeTalk MC
spada's Avatar
Greg, it sounds like you need to adjust your idle valve "Cranking(dc)". You may be opening it pretty wide, and then it slowly closes as the timer counts down. But it's also probably related to your Minimum(dc) and your Fast idle Speed. You will have to play around with all of those values in the Idle control page. Send a screenshot of that.
Old October 25th, 2017, 03:00 AM   #216
^ and dont forget about the closed loop idle initial values. If you take a log you should be able to see whats causing the high idle.
Old October 25th, 2017, 06:11 AM   #217
Greg 94 PGT
Thanks guys.
I'll poke around and see what I find. Hopefully I'll have time to play with it this weekend, and maybe get a log up here for you guys to take a look.
Old November 18th, 2017, 02:40 PM   #218
Greg 94 PGT
Okay I made a new thread here instead of cluttering up this one
