Hi all,
I'm selling a few items to fund a restoration. Here is what I have pictures of so far:
Pictures are here: https://mx6probestuff.shutterfly.com/pictures
I'm located in Baltimore, MD. Also, I would be partial to trades for Megasquirt engine management system, King6 traction bars, King6 front control arms with traction bar mounts, and AWR radiator for 2.5L.
I'll be posting more pictures and prices for some other stuff as I find the time. I have some AVC boostwerx Valant_94GT turbo hot pipes (new)+cheap ebay turbo (needs a rebuild)+cheap ebay wastegate (new) and a 19mm AWR rear anti-swaybar with endlinks for a 2nd gen in storage.
REub
- Frankenprobe's intake manifold (See Dan Sac's build thread, it's just awesome) ($980)
- New, BBK 75mm mustang throttle body that has minor cosmetic blemishes ($200)
- New, Ford mustang idle air control valve (fits the BBK) ($75)
- Moates.net Burn1 with F2A and F2E adapters to read and flash Ford ECMs (EEC-IV,V), F3 chip for EEC-based Ford ECUs allowing the stock program to be replaced with a tune of your choice, and I think a F2 (older version of the F3 with less memory) ($50)
- Wiseco pistons for KL on stock KL rods, used, I was told 9.5:1, .030" overbore and <2k ($350)
- Rurockn bulk buy rods, new, the one that was opened has cosmetic blemishes ($350)
- Welded water pump casing, in case you want to switch to an electric pump ($75)
- Used Front/Rear AWR motor mount set, for FS motor but includes spacers and also works with KL ($100)
REub
