They're in the tune files, but we generally recommend aiming for around 14.7:1 at high vacuum, around 12.6:1 to 12.8:1 at 100 kPa, and bring it up to 11.6:1 to 11.9:1 at high boost.
megasquirt - post your tables/msq here
Matt at DIYAutoTune.com
Let me know which write-up and I will check it out.Matt at DIYAutoTune.com
Matt, I was talking about the word doc and msq in the zip below:
http://diyautotune.com/diypnp/apps/n...94-klde-mt.zip
and the write-up on:
http://www.diyautotune.com/tech_arti..._mazda_mx6.htm in MegaTune Configuration for MS2/Extra
Can you just verify which settings are the correct ones. I'm still having problems with my KL, it just won't start, even with the stock disty.
DIYPNPs use slightly different ignition input and output hardware. Accordingly, the settings can be slightly different. Use the settings on the DIYPNP page only with DIYPNP hardware.Matt at DIYAutoTune.com
geez... so much for this post lasting :-/ right when i need to find a base stock fuel&spark map to start my DIYPNP v1.1 firmware: MS2 Extra 3.0.3u alpha 20100522....
I guess it's just trial and error for me So nobody wants to share their MSQ files?
1995 PGT completely stock: injectors, fuel, etc.1995 Ford Probe GT, black - Garrett GT3076-R @ 11.2psi. ~321ish whp/303ish wtq @ 19-20○ ignition, DIYPNP MS2/extra, etc. -parted & junked
1995 Ford Probe GT, black - MS3-Pro Ultimate, bone stock-ish, daily driver)
I'm a computer newb. How do I get a shot of my tables?MX-3 GS - P&P DE w/ ZE exh. cams/ pistns, KLG4 IM, 65mm TB, MSnS, Phenos, K&N RAI, Grnd wires, rear batt, AWR MMs, torq brace, TWM short shftr, Exedy, Lng tube hdrs 2.5" Side exhaust, H&R sprngs, NRG Susp./ Nyloil bushngs, strutbars, Alum. crss mmber&tiebar, 22mm swybar/ solid endlinks, Azenis, leather int, Alpine stereo & alrm, 10 Boston Accoustics spkrs, Prjectrs, Blaster3, CF hood, FG hatch/ Lexan,
using the "prt screen" button
Originally posted by fowljesse View PostI'm a computer newb. How do I get a shot of my tables?1995 Ford Probe GT, black - Garrett GT3076-R @ 11.2psi. ~321ish whp/303ish wtq @ 19-20○ ignition, DIYPNP MS2/extra, etc. -parted & junked
Originally posted by yellow2point0 View Postgeez... so much for this post lasting :-/ right when i need to find a base stock fuel&spark map to start my DIYPNP v1.1 firmware: MS2 Extra 3.0.3u alpha 20100522....
1995 PGT completely stock: injectors, fuel, etc.Matt at DIYAutoTune.com
i'll give it a shot tonight actually, Matt if my engine blows up on me then it's just my crappy soldering skills
I wish I could post mine up here... but I cannot even so much as get mine to idle correctly without dying at the moment :-(Last edited by yellow2point0; June 26, 2010, 07:25 PM.1995 Ford Probe GT, black - Garrett GT3076-R @ 11.2psi. ~321ish whp/303ish wtq @ 19-20○ ignition, DIYPNP MS2/extra, etc. -parted & junked
Here's mine. Most of my mods are in the sig.
I've got it tuned for power, and for 15.5:1 AFR at idle (about 600rpm), and up to 18:1 AFR at cruising, under very light load), and about 16:1 at 69mph, flat road, normal conditions.MX-3 GS - P&P DE w/ ZE exh. cams/ pistns, KLG4 IM, 65mm TB, MSnS, Phenos, K&N RAI, Grnd wires, rear batt, AWR MMs, torq brace, TWM short shftr, Exedy, Lng tube hdrs 2.5" Side exhaust, H&R sprngs, NRG Susp./ Nyloil bushngs, strutbars, Alum. crss mmber&tiebar, 22mm swybar/ solid endlinks, Azenis, leather int, Alpine stereo & alrm, 10 Boston Accoustics spkrs, Prjectrs, Blaster3, CF hood, FG hatch/ Lexan,
Map #1:
Map #2:
I'm not sure if that is what is currently on the car. The laptop died and I haven't replace it.¶¶¶ Spyder Mica Metallic1994 PGT ZE-T04E Intercooled @ 6 psi.. ----- Sold within NEPO and PT
¶¶¶ Arancio Atlas Metallic1995 PGT NOVI 1000 Intercooled @ 10psi. ----- STUPID FAST
¶¶¶ Verde Mica Metallic 1993 PGT Modified, Sanctified, Retired. ----- Damn I miss her.
Hey Travis, looks like you could benefit from some more timing. I'll post my SRT8 killer maps later when I wake up. About ready to drop in some 550's so all will change after this weekend.1993 Mercury tRacer :Vitara & mFactory: In progress 2020
2014 Factory Five 818s: sold
