Old August 4th, 2004, 10:34 PM   #1
kuki
Distributor connector?
Where can I buy new original OEM (identical) 6pin and 3pin distributor connectors. I need male and female (3pin and 6pin) connector to build extension cables for distributor?
Thanks
PS. If anyone knows names of those connectors that would be helpfull, too.
kuki is offline   Reply With Quote
Old August 4th, 2004, 10:49 PM   #2
Omaha95PGT
o=II=o
Omaha95PGT's Avatar
You may need to go to a junk yard. Pull the connectors off an old V6 PGT/MX6/626/Millenia2.5
Marc M.
2000 BMW M-Roadster
Omaha95PGT is offline   Reply With Quote
Old August 5th, 2004, 07:04 AM   #3
clutchless
www.mx6.com in the for sale forums there is a guy always parting out 20 MX6s. Post what you want he will reply with a price and he takes Paypal.
clutchless is offline   Reply With Quote
Old August 7th, 2004, 09:06 PM   #4
kuki
Finnaly, I found them. Manufacturer is "Sumitomo Wiring Systems, Ltd." http://www.sws.co.jp/index_e.html and they have online connector database at http://swsct.sws.co.jp/index_e.html where you can find all Ford Probe and Mazda's connectors. Nice to know when you break some of them.
Old August 7th, 2004, 09:57 PM   #5
Gro Harlem
what did you search for to find the distributor plugs? My plugs are all burnt out and crappy. I need new ones too.
Wil (admin
) 93' MX-ZE
Mods: ZE w/31 cams & curved-neck mani, 67mm t/b, obx headers w/2.5" straight-thru, 3" custom CAI,
Mazdaspeed mounts, Tochigi Fuji Sangyo 2-way LSD, ACT clutch, Noble Green Metallic paint, E-spec headlights,
OEM skirts, 16" SubZeros on Azenis, Tokico w/Eibach's, Mazdaspeed TTL & Bushing Kit, New OEM Leather seats & SE interior
Gro Harlem is offline   Reply With Quote
Old August 7th, 2004, 10:55 PM   #6
kuki
Well conectors on distributor are female 3-pin and 6-pin sealed type.
So what you need is:
Kind: Housing
Connector series: All
Terminal size: All
Way : 6 or 3 for 3-pin and 6-pin
Male/Female : F for female
Sealed
6195-0035 http://swsct.sws.co.jp/housing_e.asp...5dls&page_no=0
Maybe: 6189-1012 or 6189-1083
Those are close, and then play a little and select terminals, wire seals ...
Same for 3-pin connector
6195-0009 http://swsct.sws.co.jp/housing_e.asp...9dls&page_no=0
Maybe: HEAT-RESISTANT 6195-0247 http://swsct.sws.co.jp/housing_e.asp...7dls&page_no=0
Old August 8th, 2004, 05:53 AM   #7
Omaha95PGT
o=II=o
Omaha95PGT's Avatar
Well, the thing is, why would you want to order from Japan when the junkyard probably has the same thing for $1.
Marc M.
2000 BMW M-Roadster
Old August 8th, 2004, 09:19 PM   #8
kuki
Well, I need new one because that is supposed to be sample unit. It should look nice.
