Old October 19th, 2005, 08:42 PM   #1
funzie
HOWTO: Lower Control Arm Bushing Replacement
Well after running around with a clanking noise every time I run ove a bump, not to mention not being able to align the car and having my steering wheel jerked about at randon. I decided to get some bushings. My passenger side was completely busted. After searching for a bit I found the SuperPro bushings, I only installed the front ones which are part # SPF1843K which are ~$50 plus shipping. They also make rear control arm bushings, but I didn't get those because they were $100 plus shipping. There are 3 models for the rear bushings, regular caster, positive caster, and negative caster. You probably can figure out what is the difference between them.
This is the packaging:
What they look out of the package:
If you are wondering how the hell I got the stock bushings out, well there are two solutions. 1.) Burning them off, but the smell of burn rubber and the risk of damaging something with the torch isn't to appealing to me. 2.) I decided to put my engineering degree to the test and made my own little tool. Its basically a threaded rod, you pass it through the hole on the bushing and put a nut and washer on the end. On the other end slide over a peice of pipe bigger than the bushing. I used a 2.5" diameter, about 6" long pipe, I then got a flat peice of steel and drilled a hole through it and put another not. Now to remove the bushing just turn the nut and after a few minutes you will have witness the birth of a stock control arm bushing. Below is a pic of my tool.... well my tool is bigger than that, let me clarify, the tool I made to remove the control arm bushing.
The tool installed removing the bushing, for another angle:
Stock bushing removed:
New bushings greased and installed:
Installed and bolted on:
Another view
The other side I had to hammer the bushing out because it came apart since it was broken.
Questions...?
Just for shitz and gigglez, me tearing it up at ZoomZoomLive last weekend.
270whp - 251tq
$mycar = driving(FALSE, TRUE);
function driving($filter, $turbo) { if(!$filter && $turbo) { return TRUE; } else { return FALSE; } }
funzie is offline   Reply With Quote
Old October 19th, 2005, 08:51 PM   #2
KM_heisler
KM_heisler's Avatar
I remember last year I had to do that I had my car on my hoist for it's bi-weekly oil change and checked for play and noticed that the front of my wheel moved left and right like a good 1-1.5 inches.... I torched mine out and then I forget what I used to press it in.
Kevin Heisler
90 JDM Fairlady Z , twin turbo lots of stuff done already but not enough space in the sig
KM_heisler is offline   Reply With Quote
Old October 19th, 2005, 08:53 PM   #3
funzie
To put the front ones in you just push them in with your hands, the rear ones would be trickier.
270whp - 251tq
Old October 19th, 2005, 08:57 PM   #4
KM_heisler
KM_heisler's Avatar
I had to press mine in and mine looked pretty different.. then again mine was from mazda (around 20 bucks canadian my cost) so I dont know but I remember when I did it it wasnt a crazy amount of force needed like a c clamp did it with a piece of wood it was pretty simple. It was the first small repair I had to do on the car before that I replaced everything else so I was happy to have a little piece wear out
Kevin Heisler
Old October 19th, 2005, 09:00 PM   #5
funzie
Oh, ok, I didn't know you were talking about stock ones, yes those you would need to press in, probably the reverse of how I took mine out.
270whp - 251tq
Old October 19th, 2005, 09:04 PM   #6
knb13
PT Guru
those are poly ones right?
'04 Silver Mazda3s Hatch... not really stock
'89 Blue Jeep Cherokee 4x4....yea this isn't stock either
'46 Gray Pontiac Coupe.. this one is very stock
'02 Red/Black Honda CBR 600 F4i... some go fast goodies
knb13 is offline   Reply With Quote
Old October 19th, 2005, 09:07 PM   #7
funzie
That is correct.
270whp - 251tq
Old October 20th, 2005, 10:44 PM   #8
baaka
Yo funzie. Where'd you order them from? I found one website, but they're out of stock. Also, has anyone ever resolved the superpro problems that they were having like a year ago? I'm about to buy these, but not if they'll just screw up.
baaka is offline   Reply With Quote
Old October 21st, 2005, 06:49 AM   #9
pgt4speed
pgt4speed's Avatar
My control arm bushing was nowhere near one piece when I replaced the control arm.
Nice bushings, I should have done that 2-3 years ago I needed a new balljoint also, so no biggie.
Sandon Lettieri
1993 Probe GT - KLZE & Stuff - 172whp / 161wtq - 146k
2013 Focus ST - Stock & Stuff - 251whp / 290wtq - 142k
pgt4speed is offline   Reply With Quote
Old October 21st, 2005, 09:16 AM   #10
FRCFD6
F/I *********
FRCFD6's Avatar
when you put a new balljoint in , tack it in place
Life isn't like a bowl of cherries or peaches, it's more like a jar of Jalapenos ....
What you do today, might burn your ass tomorrow.
Pearl '92 Audi //S4 GT3071R, running 27 psi
Lava gray '14 Audi //SQ5, Chipwerke, 034 Intake Pipe
For PSP Awareness click
FRCFD6 is offline   Reply With Quote
Old October 22nd, 2005, 11:48 AM   #11
kadamsgt
Global preformance in Michigan has them listed on thier site. $50 seems to be the going rate.
kadamsgt is offline   Reply With Quote
Old October 22nd, 2005, 02:42 PM   #12
mvaughn1
PT Master
nice writeup and great pictures! Thanks for the contribution and time!
Mike
- 14.639 @ 91.54 mph N/A 2.025 60' - 2605 lbs
CS Lip ll Megasquirt ll ZE-IM ll Hotshot Headers ll PRM CAI ll Illuminas/Intrax ll 6 puck/MX3 FW ll RR Shifter ll 19" Giovanna Kobell Black Roof ll Black Leather
93 PGT-ZE - 14.433 @ 96.06mph N/A 2.159 60' - street tires - 2555lbs
ZEX ll Seli Cams ll Walbro ll Fidanza/DXD ll Addco ll PS Headers ll 65mm TB ll PRM CAI ll Blues and GC's ll MX6 Black Leather
mvaughn1 is offline   Reply With Quote
Old November 25th, 2005, 12:54 AM   #13
sparrow_34
Thanks for the great write up and pics. The 'tool' you gave instructions for making worked bloody well.
Saved me a few bucks.
sparrow_34 is offline   Reply With Quote
Old November 25th, 2005, 08:44 PM   #14
ouch1011
ouch1011's Avatar
Hmm, I may have to do this when my car is sitting without an engine.
What solutions do we have for the rear-most front control arm bushing? The one that is in its own housing and bolts to the body and the control arm?
Kevin B - Former Probe-owner
ouch1011 is offline   Reply With Quote
Old November 25th, 2005, 10:01 PM   #15
funzie
That would be the caster, they also sell that one. With different types of caster too, +/- and stock.
270whp - 251tq
Old November 28th, 2005, 12:24 AM   #16
ouch1011
ouch1011's Avatar
I am unsure how this bushing would affect the caster...
I will take a picture of the one I'm talking about tomorrow, just so I can make sure we are on the same page.
EDIT: OK, this isn't on the car, but hopefully you can figure it out. This is the REAR bushing on the FRONT control arm...
Old November 28th, 2005, 06:17 AM   #17
funzie
Yes, that would be this one:
And according to them, this one increases camber:
And this one decreases it:
270whp - 251tq
Old November 28th, 2005, 06:49 PM   #18
ouch1011
ouch1011's Avatar
Gotcha, thanks...
I think I'll add these to the "to buy" list
Old April 22nd, 2006, 05:15 PM   #19
danieldepetro
Five Star Member
danieldepetro's Avatar
Nice thread! I was going to just replace my front lower control arm bushing as I already have the urethane ones awaiting installation, however now I guess I'll order urethane rear LCA bushing as well...
1969-1/2 Dodge Super Bee (A12, M-code, 440 Six Pack, 4-speed , Dana 60 rear w/4.10 gears)
1973 Plymouth Duster (225 Super Six, aluminum 4-speed O/D, 8.25" rear w/3.55 gears)
1974 Dodge Dart Sport (406 big block, aluminum 4-speed, 8.75" rear w/3.91 gears)
danieldepetro is offline   Reply With Quote
[IMG] code is On
