Old September 23rd, 2009, 10:12 PM   #1
artsvetkov
How-to: Taller 5th gear using PSE/Escort gears
So today went out to junk yard to get taller 5th gear after reading this thread http://forums.probetalk.com/showthread.php?t=1701282253
I was looking for 93-97 Probe SE but someone already took the 5th gear set, so I ended up getting gears from newer escort, but they should be the same.
So this is what you need
Tools
1/2 impact gun or breaker bar and a lot of muscle.
32 and 26 mm sockets to get the lock nuts of PGT tranny
Chisel and punch set
10mm, 23mm and 17mm sockets
RTV
Gears
http://i30.photobucket.com/albums/c3..._5059Large.jpg
So first jack up the car and drain transmission fluid (23mm socket to open the drain/fill plug)
Remove splash guards
Then lower the transmission so the end cover clears the frame
you can do it by removing crossmembers and losing top trans mount (17 mm bolts)
Then remove 10mm bolts from end cover and pull the cover off.
Using chisel unlock the lock nuts and remove them (32mm and 26mm)
http://i30.photobucket.com/albums/c3..._5060Large.jpg
Next step is to remove pin that holds the alum selector arm on the shaft (use punch), you can see the pin from the bottom.
Remove First gears on each shaft, then grab the whole gear assembly(from syncro to syncro) on the left and pull it off with the selector arm.
Now we got to the gears
http://i30.photobucket.com/albums/c3..._5061Large.jpg
Pull them off and replace them with taller ones, then assemble in reverse order.
When you go to put the lock pin back, you can squeeze the pin with pliers and drive it in with hammer.
Tq the lock nuts to 95-140 ft-lb and lock the nuts with the punch and hammer.
scrape the cover and tranny surface, reseal and reinstall it.
put everything back together, let RTV cure, fill the oil and take it for a spin.
After I tightened the lock nuts, I put car in 5th and started to see if the wheel are spinning, if they do, you win. make sure both wheel are of the ground to prevent fail.
here are escort gears on the bottom and PGT on top
http://i30.photobucket.com/albums/c3..._5062Large.jpg
-sold,
12" brakes, ZE, T3/T4 turbo, 2.5" exhaust , ACT 6-puck, MSD6AL+2step, Coilovers, 245/45/17x9 cobra r, 67mm TB, MS II, traction bars, meth inj. and more.
artsvetkov is offline   Reply With Quote
Old September 23rd, 2009, 10:41 PM   #2
z28forlife
Nice write up man. I didn't think someone would go out so fast and do this. Thanks for doing the leg work.
1996 PGT-T...SOLD
N20 is like a beautiful women with an STD: you wanna hit it but your afraid of the consequences.
z28forlife is offline   Reply With Quote
Old September 23rd, 2009, 11:00 PM   #3
jasons96pgtze
Colt Cams BB Master
great job man that is quick
jasons96pgtze is offline   Reply With Quote
Old September 23rd, 2009, 11:03 PM   #4
artsvetkov
Since the RTV is drying, I will fill it up and take it for a spin tomorrow after college.
-sold,
Old September 24th, 2009, 12:30 AM   #5
norweja96
Impressive dude, i love seeing write ups. Way to go on expertise and speed. Double thumbs up for you! What kind of results are we looking at here?
Timberline grey 96 pgt 5sp. Lowered on 18's w/ a custom sts stolen and M.I.A.
Noble Green KLZE'd MX-6 LS 5sp, STS, HID's and Yellow Fogs, SSAC'd,2.25 catback, KN'd, lip'd, CF hood, sittin low on H&R coilovers,Strut bars and 626 sway bar, FD's and bumpin'
norweja96 is offline   Reply With Quote
Old September 24th, 2009, 03:53 AM   #6
j-dogg
/p/hotoPOC
j-dogg's Avatar
Location: pwning the crap out of supersquid in Unreal Tournament
I request teh sticky.
PhôtôPOC(tm)
MM9 MMX FF FF2 FF3 FF4 FF5
95' base 299k of DD sex on factory-sealed motor and climbing, Eibach pro kit, chrome swirls, 626 swaybar, front and rear STB's, Frankenprobe's Brembro rotors, ice-cold AC
93' PGT 157k stocker current boost project, JVC headunit, Alpine audio, trans saver, STBs
91' PLX MTX 248k. 2.5" into a Flowmaster 40
j-dogg is offline   Reply With Quote
Old September 24th, 2009, 05:35 AM   #7
Alexklze
How to: 30+ MPG and reduce engine wear.... I can't believe we didn't do this sooner!
, ZE, I|H|E|11lb FW|67mm TB|South Bend S2|Poly MM's|B&M STS|JJ Resy TP|Blue's|Eibach's|17mm Swaybar|Electric Cutout|Ethanol-Free Gasoline|210's & Nitrous..
, Barn Find, I|Rats
, Sold
, I|H|E|FW|MS
BOOST IN FIFTH!!!!!
Alexklze is offline   Reply With Quote
Old September 24th, 2009, 07:39 AM   #8
Kov
Whats your RPM at 60mph?
Built by Ford.....Engineered by Mazda....
Rebuilt, Re-engineered, and Redefined by Kov.
New Probe in 2013, let the S/C fun begin!
Kov is offline   Reply With Quote
Old September 24th, 2009, 07:41 AM   #9
JazRedGT
Junior MODARATER
JazRedGT's Avatar
Amazing write up and Def great for our gas milages!!!
1993 PGT-DE-T Silver Surfer - 8psi
2004 Acura TSX - Wife Mobile
JazRedGT is offline   Reply With Quote
Old September 24th, 2009, 10:17 AM   #10
Runner
i'd really like to see how much of a gas mileage increase this will net. wonder why they went to shorter gears in the obdII probes
96 PGT. Pacesetter 2.5" Catback, Test Pipe, ChromeIntakes CAI, Clear Corners, Pilot Fogs, 3rd brake light GT symbol, sts, squeaky clutch mod,
2004 Suzuki GS500F. Polished Rims, broken fairings mod.
Runner is offline   Reply With Quote
Old September 24th, 2009, 10:36 AM   #11
FuLcRuM
I've been running a 2.0 5th for a couple years now.
I also have the 4.11 final so I'm even taller.
70mph = about 2800rpm
95 Black Probe GT
Currently being parted out.
FuLcRuM is offline   Reply With Quote
Old September 24th, 2009, 11:08 AM   #12
dna59
I think this is something I definitely need to do. Thanks for the write up.
1997 Ford Probe GTS
2004 Giant TCR C2
dna59 is offline   Reply With Quote
Old September 24th, 2009, 12:28 PM   #13
CSFiend
I'm planning on doing this when I pull the trans to replace my clutch. Thanks!
CSFiend is offline   Reply With Quote
Old September 24th, 2009, 01:11 PM   #14
MIHELA
If anybody wants the part numbers for the lock nuts, I got them from our Mazda store. Mazda recommends you replace them, although its probably not really necessary. They are a little spendy but less than another trans if one were to break or back out.
F520-17-628 and F521-17-628A
1997 Ford Probe GTS "Optimus Probe" - SOLD
2005 Impreza RS Wagon "Silverstreak"
2006 Pontiac Solstice "Jazz"
MIHELA is offline   Reply With Quote
Old September 24th, 2009, 01:45 PM   #15
Juans 93 MX3
Not Politically Aware Member
Whats the difference between the gear ratio (5th gear) on that Escort and the gear ratio on a MX3 and Probe tranny?
1993 MX3, KLZE & 5 Speed Swap
2008 Mazda 3 Sedan Sport
Juans 93 MX3 is offline   Reply With Quote
Old September 24th, 2009, 02:53 PM   #16
MIHELA
.717 versus .795
Old September 24th, 2009, 03:17 PM   #17
j-dogg
/p/hotoPOC
j-dogg's Avatar
Originally Posted by MIHELA View Post
.717 versus .795
That's a big difference.
I think the next question is if anyone has a bolt-on ZE and has topped out one of these setups.
PhôtôPOC(tm)
Old September 24th, 2009, 03:49 PM   #18
DroptAtBirth
DroptAtBirth's Avatar
what year escort did you pull these gears from?
DroptAtBirth is offline   Reply With Quote
Old September 24th, 2009, 04:12 PM   #19
Ford427
Definately Sticky worthy
89 PGT: DD, stock until spring
Ford427 is offline   Reply With Quote
Old September 24th, 2009, 04:21 PM   #20
BliZzArD599
nice writeup. whats your rpms @ 60mph now? i vote for sticky
BliZzArD599 is offline   Reply With Quote
Old September 24th, 2009, 05:36 PM   #21
artsvetkov
I get 2600-2650 rpm @ 60 and 3k @70 which is what most of the 90's cars have. top speed should be somewhere around 155mph
What ever year has the same looking tranny as probes(except for the bell housing) would work, I started on 94 escort(boxy) but after I popped the cover I couldnt get the gears to lock up so I can unscrew the nuts, then I went to 97+(round looking) and the gears looked the same so I got them. Both cars had SOHC engine.
-sold,
Old September 24th, 2009, 06:24 PM   #22
Staats
Great write up, I may have to do this as my bosses shop has an SE's tranny sittin in back.
- Installed: CAI, VIS CF Invader hood, OBX headers, Res. T.P., Borla Catback, Civic STS, Brembo X-drilled/slotted disks w/PBR ceramic, '01 626 rear sway bar, MX3 Flywheel, Enkei TBS11s w/Kumho Ecsta SPT's, F & R strut ties, 96+ Tails.
MMX Winner: Best in Class Show Room
Staats is offline   Reply With Quote
Old September 24th, 2009, 06:51 PM   #23
j-dogg
/p/hotoPOC
j-dogg's Avatar
I would think a 4.11 with Escort gears would top a lot higher.....considering a stocker 4.39 is doing 155 @ 7500 rpm, a stock 4.11 does 166 @ 7500 rpm.
There's a thread on it here somewhere.
PhôtôPOC(tm)
Old September 24th, 2009, 06:57 PM   #24
Kov
well i m hitting up the j/y tomorrow. Maybe they got some PSE's in since I was there last, but the did have a 1g GT there. So i know what I m going to be getting
Thanks for the write up man! props!
Old September 24th, 2009, 07:02 PM   #25
JKpgt96
Drives Light Blurple Car
JKpgt96's Avatar
I have had this in every transmission that I have put in my car, so...5-6 years now? Good write-up. I usually put the car in gear, then remove the pin from the shift fork then engage 5th. This in effect locks up the transmission so it is easier to bust loose those nuts on the end of the I/O shafts..but w/e method works.
You can also use n/a 2.2 1g 5th gear, or a festiva 5th if you REALLY want a big drop in rpm..but I found that the festiva gear is overkill and makes any sort of acceleration tough at highway speeds in 5th..
JKpgt96 is offline   Reply With Quote
