Old July 22nd, 2017, 10:16 AM   #1
klzeprobe
How to check cam sensor wiring
It's a 95 pgtze not starting. No spark.
I've got code 03 which the cam sensor. I have a brand new distributor in it. I just want to know how to test the wiring to make sure it's good. Can someone explain that to me? I can't find anything in the search.
Thanks.
95 pgtze RIP
93 pgtze the powerplant of my 95 lives on.
94 pgtze-t Work in progress.
95 pgtze DD
63 Pontiac Catalina 389cid stock except for MSD
klzeprobe is offline   Reply With Quote
Old July 22nd, 2017, 10:45 PM   #2
Okay, so there's 2 things 93-94 used a cam sensor. 95 didn't use the same cam sensor. There may be a Blue and a Green wire on the distributor that gets the crank pos sensor run through it to pick up a pulse from the cam sensor that is in there. If that wire wasn't good you'd have a crank sensor code though? Maybe someone else can explain it better. Worst case I can look at mine tomorrow in the light.
Old July 23rd, 2017, 09:18 AM   #3
klzeprobe
Is there a way to test the wire for continuity with a basic multimeter? Just trying to figure out if it's the wiring or if I got a faulty reman disty.
95 pgtze RIP
95 pgtze DD
Old July 23rd, 2017, 01:38 PM   #4
The crank sensor signal goes through those wires, so if you don't have a crank sensor code the wires should be good. You can get it to run on a 94 disty if you have one... with some wire swapping. If it works then you know that's the problem. Run it on the 94 disty til you get the new part.
Old July 29th, 2017, 06:14 PM   #5
klzeprobe
So I have checked the wires. The three plug has a wire with 12v and the 5pin plug has a 5v and a 12v. Disty is brand new reman. Still no spark. What am I missing?
95 pgtze RIP
95 pgtze DD
Old July 29th, 2017, 11:48 PM   #6
I've gotten bad reman distributors before. I'd say bring it back to the store you got it from and exchange for a new one.
Old July 30th, 2017, 02:27 AM   #7
Whitefinish
Check the relay next to your ecu.
Those are faulty sometimes and also cause no spark.
Mazda Mx3- Panther black, Kosei 18", custom hood, cleaned, new pakfeifer front, customized pakfeifer rear
KLZE highcompression, Pippercros Viper intake, kl31cams, MS1 v3, Aasco fly, CM st3 clutch, cai, ss headers, ground wirekit, srd bushings, msd window switches, nitrous
Whitefinish is offline   Reply With Quote
Old July 30th, 2017, 05:14 AM   #8
klzeprobe
Which relay is that? I didn't know there was a relay by the ecu. I'll check that and if that doesn't work then exchange the disty.
95 pgtze RIP
95 pgtze DD
Old August 5th, 2017, 12:36 PM   #9
klzeprobe
So I ran the tests in the THIRD picture down here: https://mazda626.net/topic/45372-ple...lp-95-hei-mod/. PIN number 2 on the small plug failed. No flicker. Am I supposed to leave the plug installed. I did it unplugged for all tests and everything passed except pin 2.
What should I do?
95 pgtze RIP
95 pgtze DD
wtb: KLG4 cam sensor and cam wheel polarexpress17 Wanted 5 September 17th, 2011 06:43 PM
MIlenia KJ Cam Sensor wiring diagram ausloki Engine Electronics 10 September 13th, 2010 03:43 AM
Cam position sensor check speedklz 1st Gen (89-92) All 0 July 29th, 2008 06:25 PM
Cam Angle Sensor (aka disty crank angle sensor) tehbrookzorz 2nd Gen (93-97) V6 2.5L 1 May 7th, 2006 02:09 PM
