Old August 9th, 2017, 07:56 AM   #1
Probesport
20 years of Probin'
Probesport's Avatar
Weird temp gauge issue, only reads with RPM
I haven't had a chance to look into it yet, just wondering if anyone else has seen this.
My temp gauge all of a sudden is acting a fool. At idle/low RPM it sits at the bottom (cold) and only goes back into range with throttle. It gets to normal as it should and stays there until RPM drops down again. No overheating, fans working just fine, no other issues.
I'm assuming the gauge is going bad but I'll swap out the sensor tonight as well.
Is this how the gauge itself dies?
| 2005 VW Touareg V8
Probesport is offline   Reply With Quote
Old August 12th, 2017, 05:26 PM   #2
NickR
Weird. Just a wild guess, but check the coolant level. At higher rpm the water pump will be working faster, and maybe getting coolant to the sensor???
Oil gauge issue (reads middle even with engine off) Bit_reaper 2nd Gen (93-97) V6 2.5L 6 August 19th, 2016 06:02 PM
temp guage reads hot-- when cold projectplatinum 2nd Gen (93-97) I4 2.0L 2 October 3rd, 2009 03:56 PM
no heat/temp gage reads cold kblack 2nd Gen (93-97) I4 2.0L 4 March 7th, 2005 01:54 PM
Cyberdyne FP Gauge only reads - - My_Probe_is_faster Forced Induction (Turbo/S.C.) 3 February 7th, 2002 02:20 PM
