Old October 8th, 2017, 10:22 AM   #1
hydrolastic
KLDE KLZE cam specs wanted
Hello guys, Entering specs into the performance trends computer software. I have two engines a KLDE and a KLZE. I need the cam specs for both engines. centerlines intake and exhaust and duration, lift. Specifically I am looking into the legend that the cam timing is 4 degrees advanced. since my car is track only i want more HP from 4000 rpm and up. I have looked all over for accurate info and have come up with nothing. Also if nobody has the info, i plan on reverse engineering the cam timing and will degree each engine to see what the actual specs are. Hydro
hydrolastic is offline   Reply With Quote
Old October 8th, 2017, 03:43 PM   #2
SBPGT
Five Star Member
SBPGT's Avatar
http://davidandjemma.com/mazda/KL.htm
Currently buying all my parts for my future part-out thread...
STEVE B
2002 Mazda 626 ES
SBPGT is offline   Reply With Quote
Old October 12th, 2017, 03:45 PM   #3
SuperSquid
It's all J-dogg's fault
SuperSquid's Avatar
I have thought about adjusting the cams a tooth off between the exhaust and intake cam on each bank to move the overlap and then flip the cam gears and use a new mark for timing belt alignment. The flipped cam gears would move the cams ~3.5
Old October 13th, 2017, 08:38 PM   #4
xrp861
You're aware flipping them isn't going to do anything but confuse you seeing as most kl pulleys are able to be flipped for either head.
94 PGT
KLZE cam vs KLDE cam Jmalonejr93gt 2nd Gen (93-97) V6 2.5L Performance 45 December 16th, 2013 06:32 PM
Rod bolt torque specs, rod journal specs Anyone? short4stuff 2nd Gen (93-97) V6 2.5L 1 October 23rd, 2013 08:30 PM
wanted klze cams and good klde or klze heads no13regrets Southern California Probe Owners Club 10 August 12th, 2009 06:07 PM
klde replacement (klde-klde) blindsided145 2nd Gen (93-97) V6 2.5L 3 May 17th, 2005 11:20 AM
