Advertise with ProbeTalk - click here to find out how! Forums
Go Back Forums > Tech Section > 2nd Gen (93-97) V6 2.5L
Old October 11th, 2017, 03:31 AM   #1
Water leaking onto driver's side floorboard
I have a big leak coming from somewhere in the upper corner of the dash. The only thing that I can think of that might be causing it is the hood hinge. Do the bolts protrude to the inside of the cabin? I can take a water hose and aim it for that area and it definitely starts leaking down onto the floorboard. The windshield doesn't leak and the sunroof drains are also good. But water is getting in from either the hood hinge or around the area at the corner of the cowl . Does the fender bolt onto the body anywhere that could cause a water leak? It looks like the hood hinges at the body have some sort of seam sealer around them. Is this correct?
jimtash is offline   Reply With Quote
Old October 11th, 2017, 08:14 PM   #2
Yes, they do, it is possible. Did u take off the black plastic cowl?
Some people are living life and some people are just living.
yellowrob is offline   Reply With Quote
Old October 15th, 2017, 01:19 PM   #3
Under the cowl there is another small plastic cowl fitted with butyl rope and clips. Check this.
sbeube02 is offline   Reply With Quote
Clutch fluid leaking inside drivers side floorboard and other issues!!!! nstigator 1st Gen (89-92) All 5 February 16th, 2006 08:28 AM
Help!!! My pass. floorboard's all wet! JoshSmith 1st Gen (89-92) All 7 March 6th, 2005 10:33 PM
FS: driver side window motor and driver side switch keq PT Member Sales 0 February 11th, 2004 01:33 PM
what the hell is that pounding my floorboard?? jarredsyxx00280 1st Gen (89-92) All 8 October 23rd, 2003 09:51 AM
Copyright ©2000 - 2018, vBulletin Solutions, Inc. is not affiliated in any way with the Ford Motor Company, the Mazda Motor Corporation, or any subsidiaries of either company.
All views and opinions expressed on this message board are those of the author and not the owners of
