vris test
This topic is closed.
  • vris test
    how do you test your vris to make sure they are working properly?
    1994 Acura Integra GSR
    Oh goody! I love this topic!
    First, open the hood, with the engine off, and look at the two VRIS actuators. They are now in the closed position.
    1. Simple idle test. Now start the car and let it idle. VRIS#1 (passenger side) should now come open as soon as the engine starts, and VRIS#2 (driver's side) should stay closed. Now, disconnect both VRIS solenoids, and plug the wire that was in #1 solenoid into #2 solenoid . VRIS#2 should now open. (Unplugging the solenoids will cause an ecu code, of course). (The black connector normally goes to the #1 solenoid, and the brown connector to the #2 solenoid).
    2. OBD1 Self-test: Let the car idle (to build up vacuum in the reservoir) then switch engine off, then short the TEN and GND pins in the little black "DIAGNOSIS" box (next to the fuse box under the hood) with a paper clip. Then have someone turn the ignition key to "on", while you watch the VRIS actuators. Both VRIS actuators should open briefly then close.
    3. Road test: Disconnect VRIS #1 solenoid. Go for a drive, and use wide open throttle. You should notice low torque around 4,000rpm, then a sudden burst of torque at 4,250rpm, if VRIS#2 is working. Now reconnect VRIS#1 and repeat. You should now notice stronger torque at around 4,000rpm, so there is no longer the sudden jump in torque at 4,250rpm. If so, then VRIS#1 is working too.
      thanks i appreciate it
        Or the paper test.
        1996 PGT-T...SOLD
        N20 is like a beautiful women with an STD: you wanna hit it but your afraid of the consequences.
          the paper test does not ensure you have adequate vac at WOT from the chambers/check valve and threfore the test above is more accurate in my opinion. The paper test is always good as a quick check but the one above obviously better.
          Supercharged - 94' PGT: ZE, MS2, W/M Injection, weight reduced, manual steering because weekend race car! mods and pics thread
            Yeh I know, but I was just throwing the paper test in the mix because it's also a that has been used. But your right so we'll leave it at that.
            1996 PGT-T...SOLD
              I always check mine by getting in front of the car, parking brake (hand brake) manually revinf and checking 1st and secind vris opening well. Also i have someone at drivers side tell me when it hits 3100 rpms and thats when the first opens and the other at 5000 rpms.
              KLZE TURBO 5 psi untunned and all bolt ons.
